rear end damage and swap
Old Jan 27, 2014 | 08:02 PM
blp226's Avatar
Less than an hour ago my rear end blew out. At least I think it did. The engine runs good, the trans shifts good, but the rear end started making terrible grinding and scrapping noises. There is an 89 at the local pull-a-part. I think this 89 is a V6 car. Will the rear ends change out direct or are there differences?
Old Jan 27, 2014 | 08:50 PM
big gear head's Avatar
Re: rear end damage and swap
If your car is a '82 to '92 then the '89 rear end is a direct swap.
Old Jan 27, 2014 | 10:47 PM
blp226's Avatar
can I just swap my brakes as a whole unit or do I have to take the brakes apart?
Old Jan 27, 2014 | 11:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It depends what's already in your car. We don't even know what year yours is.
The diff swap will probably have a different gear ratio. Your speedo will be out unless corrected with a different speedo gear set in the transmission.
Old Jan 27, 2014 | 11:13 PM
blp226's Avatar
Mine is a 92 RS v6 5 speed.
Old Jan 28, 2014 | 06:54 AM
So this swap will be a downgrade. Your '92 has 28 spline axles and the '89 will have 26 spline axles. What brakes does your car have and what brakes are on the '89?
Old Jan 28, 2014 | 04:28 PM
blp226's Avatar
It's a V6 car, so at this point all I need is it back on the road. once I get another car it will become a project, but for now it's my only transportation. Will the spline count creat any diffeculties in doing a swap? My car has drums and I believe the junkyard car does as well. Can I just swap my drums onto the new rearend?
Old Jan 28, 2014 | 06:12 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
the spline count only matters if you swap in a posi.save the axles from the trashed rearend.the brakes should be the same.
Old Jan 28, 2014 | 07:16 PM
It should swap with no problems. If the brakes on the '89 rear end are good then no need to swap them. Hopefully the gear ratio will be the same.
Old Jan 28, 2014 | 10:10 PM
blp226's Avatar
What the gear ratio supposed to be for a 92 V6 with a 5 speed? This 89 is also a V6 but I think it has an auto trans in it.
Old Jan 28, 2014 | 11:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
According to the TGO database, a 92 V6 with a manual transmission will have 3.42 gear ratio. The automatic trans got 3.23 gears.
An 89 V6 got 3.42 gears for both manual and auto transmissions.
At least that's what came in the cars from the factory. After all these years, anything could be in the diffs.
Old Jan 29, 2014 | 01:43 AM
blp226's Avatar
So the gear ratios should be the same between the 2 rear ends, the only difference should be in the spline count which won't make a difference in actually doing the swap?
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
