Shift kit in a used transmission
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
Just wondering if it is a bad idea to put a shift kit used 700r4?
Car: check
Engine: check
Transmission: check
Re: Shift kit in a used transmission
If the transmission is still OK, then installing a Trans-go kit can extend the life of it.
RBob.
RBob.
Look to see if the bottom of the pan is clean or has very little clutch/band material in it. This will be away from the magnet. If it is clean, then installing the Shift kit and Corvette servo should help it work better and live longer. I offer the modified TransGo Shift kits that will give you what you need and want here. Let me know if I can be of help.
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
dhonda200
Aug 11, 2015 11:50 PM
