differential carrier size?
Old Mar 4, 2014 | 11:30 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
im wanting to buy a locker for my car but am unsure on my carrier size. i know i have 3.42 gears, its a govlock rear axle. and is original to the car and is correct through the rpo codes. the car was originally a v6.
Old Mar 4, 2014 | 12:24 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: differential carrier size?
If I understand the question correctly, you need to order a locker for a 7.5" 10 bolt with 26 spline axles.
Old Mar 4, 2014 | 02:08 PM
Engine: L31 350
that's what I needed thank you
Old Mar 4, 2014 | 04:08 PM
big gear head's Avatar
If it's a '86 rear end then the 26 spline will be correct. You need a 3 series to work with the 3.42 gears. If you are looking at one of the Power Trax lockers then it will not work in the Governor Lock differential case. You will have to swap the differential case for a standard 3 series before you can instal the locker.
Old Mar 4, 2014 | 04:18 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Probably not.
I bet you're going to remove the cover and post pictures though.
Old Mar 4, 2014 | 10:55 PM
Engine: L31 350
its an original 3.42 car. The gears were in it from the factory.but I didntknow the gov lock case was dkfferent.
Old Mar 4, 2014 | 10:57 PM
Engine: L31 350
Originally Posted by jmd
Probably not.
ill post pictures if needed. Id like to know what it is before I rip it out.
Old Mar 5, 2014 | 06:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 10-Bolt FAQ at the top of the page has pics. My 'guess' is that the car is equipped with an Auburn.
JamesC
Old Mar 5, 2014 | 06:51 AM
V6 cars usually had a standard differential. It would have been a special order if it has anything else.
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
