Eaton Posi Differential-which one?
Hi,
I have a 1984 Z28 HO. It is a project car, and I am slowly restoring/modifying the car. I started to work on the differential because I thought something was wrong. Sure enough, I pulled the differential cover, and Gov-loc posi unit is blown. Metal parts at the bass of the housing etc. I have gruesome pictures.
Since it is blown and needs to be replaced, it seems like a good time to upgrade, and upgrade to stronger axles. I have read all the FAQs and many threads, but I cannot find a definitive answer to a question I have.
This Eaton unit (19663-010), I know is a direct bolt in replacement for my car with 26 spline axles:
http://www.jegs.com/i/Eaton/362/19663-010/10002/-1
The Eaton unit 19599-010 is for 1988-09 GM 10-bolt 7.5" ring gear with 28 spline axles:
http://www.jegs.com/i/Eaton/362/19599-010/10002/-1
Jegs sells 28 splines axles, but will they fit into my 1984 housing? I remember reading that the 88-09 had longer axles.
Who would make 28 spline axles that would fit the Eaton 19599-010 unit and my 1984 housing?
Thanks in advance.
Thanks in advance.
Car: check
Engine: check
Transmission: check
Re: Eaton Posi Differential-which one?
I would definitely go with the 28 spline axles with the Eaton.
The wider diff's started in 1993 for the f-body's. This was the start of the 4th gens.
RBob.
RBob.
Thanks! One more question. I remember BigGearHead said to stay away from the Alloy USA axles because of improperly machined C clips. How are the Motive Gear axles? What brand would you recommend? Thanks again.
I read the 10-bolt FAQs again, and i think I will get these:
http://www.jegs.com/i/Moser+Engineer...02804/10002/-1
The best axles I have ever used are the Superior ones. Part # EV10-4. http://www.streetsideauto.com/p/supe...nd-gear-ev104/
They're about the same price as the Moser or Alloy ones. But altogether better in every way than any of the others.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I beleave you can get a much better price on that Eation Posi. at Toms Diffrentials along with the top of the line Timken berings and seals.
= http://www.tomsdifferentials.com/
Heres a link to my build = https://www.thirdgen.org/forums/tran...de-photos.html
Thanks to everyone. Tom's Differentials does have the best price. I saw your thread USMC on the diff rebuild, very nice. I like the look of the diff cover. Does it some practical value, such as reduction in heat, etc?
Most after market covers will be a little deeper, allowing you to add more oil. This will help some in reducing the oil temp. The T/A Performance and other covers with the preload bolts will strengthen the rear end by supporting the bearing caps and bracing the huge hole in the back of the housing.
Engine: TBI,5.0
KO1
16
Oct 15, 2015 05:00 PM
