T56 pedals question
Old Mar 15, 2014 | 10:13 PM
kitt462d's Avatar
Car: 1985 TA
Engine: 350 Carb
T56 pedals question
Gathering parts for a T56 swap. Do I need the pedals from a T56 car or would a set from a V6 5speed work too? I suspect they are different, but just checking. Thanks.
Old Mar 15, 2014 | 10:49 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: T56 pedals question
Either will work. thirdgen pedals have better firewall bracing but the wrong geometry. This can be corrected by making the mastery cyl rod adjustable or running a cavalier slave cylinder. Or you can go with 4th gen pedals and those require cutting off the gas pedal assembly and dont have the extra bracing. But factory type hydros for a fourth gen will work perfectly with them.
It's your call. Both will work.
Old Mar 16, 2014 | 01:07 PM
Teal92's Avatar
I had the same questions. Easiest way of doing this is using the 3rd gen pedal assembly and buying a Hawks adjustable clutch master cylinder. Give them a call and they'll get you set up. Its a "plug and play" setup. By the way the GTO and 4th gen F-body slave cylinders are absolute crap.
Old Mar 16, 2014 | 01:59 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Got a 4th gen pedal set that has been modified to bolt in with no problems pm me if your interested
Old Mar 16, 2014 | 06:19 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I wouldn't.
https://www.thirdgen.org/forums/afte...ing-knock.html
Luckily you can get it directly from Ticks.
Old Mar 16, 2014 | 09:17 PM
Teal92's Avatar
Originally Posted by jmd
I wouldn't.
Well now isn't that interesting! I had a Tick MC on my GTO and loved it, but I just figured while I'm compiling a shopping list from Hawks that I'd just throw that in there too. Thanks for the heads up!
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
