10-bolt rear end limit?
Old Mar 21, 2014 | 04:39 PM
89 Z/28's Avatar
Car: Camaro
Engine: 305ci
Transmission: 700-R4
i wanted to know if i can still use the 10 bolt i currently have. 1st i'll start off by saying the 10-bolt will be fitted with moser 28-spline c-clip axle's, moser's performance girdle(cover) and ring and pinion(3.73) from richmond and an auburn pro series differential.Now the powerplant will be a 406ci making around 600hp, the car currently weighs 3400lbs with the stock 305 in it right now when i swap in the 406 i will be putting a tubular k-member & upper and lower a-arms plus a fiberglass hood so im hoping the weight will go down to around 3250-3300lbs. Now the car WILL be my DAILY DRIVER and i will be running slicks when at take it to the track every weekend. Just wondering if the 10-bolt with those upgrades will be able to handle that. any information is greatly appreciated you guys are the experts here
Old Mar 21, 2014 | 04:57 PM
big gear head's Avatar
Re: 10-bolt rear end limit?
First of all scrap the Auburn idea. It's junk and it will not work for long when doing burnouts. Go with the Eaton Posi, Eaton Truetrac, Torsen or Yukon Dura Grip. A Detroit Locker would be best for drag racing, but you might not like it for every day driving.
The 7.5 10 bolt will not hold up well with slicks and 600 HP. You will most likely break it and all of the money you spent on it will be wasted.
Old Mar 21, 2014 | 07:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I ran a beefed up 10 bolt down into the low 11's before swapping it out for a 9". No matter how much money you invest into trying to make it better, the tiny ring and pinion teeth will still be the part that fails first. Mine didn't fail but every time I launched, there was a chance it could have failed. At the time, I was making around 500 hp to the wheels.
A big power upgrade isn't just about the engine, the rest of the driveline also needs to handle the extra power. If you're building enough power that the tiny stock diff isn't going to handle it, prepare to invest more money into a real diff that can. A 9" and 12 bolt are the most common but a Dana 60 is also available.
You can invest in one diff now or break the invested money of a 10 bolt then invest in a better diff later. No matter what you do, the 10 bolt will eventually fail. You're just rolling the dice as to when.
Old Mar 21, 2014 | 07:40 PM
89 Z/28's Avatar
Car: Camaro
Engine: 305ci
thanks for all the information guys.......What kind of rear what you recommend i use(im on a budget)....would it be easier for me to find a 12 bolt? dana for me is too expensive and can't really find any anywhere
Old Mar 21, 2014 | 07:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I may be one of luckier people with 10 bolts. I've well into the 9's on a stock 00 trans am 10 bolt.
Been 10's on another with spray, 1.41 60 ft.
I say find a 4th gen version with a zexel torsen diff and 3.42 gears. Run it as is no upgrades because it would be a waste.
Autos with a converter shouldnt hurt it that bad. Save for a new rear.
Old Mar 21, 2014 | 09:15 PM
You are not going to find a 12 bolt, or any other factory built rear end that will fit. You are going to have to go to the after market for a good rear end upgrade. Moser Engineering, Strange and some others make bolt in rear ends in 9 inch, 12 bolt and 60 for the 3rd gen. Quick Performance probably has the lowest cost bolt in 9 inch.
Old Mar 19, 2017 | 11:13 PM
Dscott's Avatar
Car: 89 Iroc street car
Engine: Fitech vortec 400sbc/T5
Transmission: Also 69 Chevelle, Nascar chassis
Axle/Gears: 700hp roadrace track day car
Great info
Old Mar 20, 2017 | 02:36 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Originally Posted by 89 Z/28
Now the powerplant will be a 406ci making around 600hp. I will be running slicks when at take it to the track every weekend.
10 Bolt = No Way
These are photos of the 10 Bolt ring and pinion next to the very popular Ford 9in. ring and pinion.
A lot of track cars including our Third Gens are using a modified version of the Ford 9in. in there cars and by looking at these photos you can see why.
By the way, I did "Up Grade" my 10 Bolt for my 5.0, automatic but its my DD and will never see a track or slicks.
Here's a link to the build thread. = https://www.thirdgen.org/techboard/t...de-photos.html
Old Mar 20, 2017 | 08:28 AM
Ron, this thread is almost exactly 3 years old and 89 Z/28 hasn't been on here for 2 years. Someone brought up an old thread again.
Old Mar 23, 2017 | 04:08 AM
Engine: TBI,5.0
OK, sorry
Not paying attention again.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
