T56 pedals question
Old Mar 24, 2014 | 06:10 PM
tjvz28's Avatar
Car: 91 Camaro Z28
T56 pedals question
hello I was able to get my 4thgen pedals in just fine with out firewall padding. I put the clutch brake pedal in and bolted to firewall first to mark holes for slave and drilled them out. also when I had it bolted up the top bolt that everyone drills out lined up great.
Question is how important is the padding should I unbolt the slave and put the piece back in there.
When I put the pedal assembly in with padding there, the bolt on top and slave holes in padding were not lining up
Also the clutch slave rod lines up pretty good with pedal better than the sticky done some years back
Old Mar 24, 2014 | 06:26 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: T56 pedals question
On mine, I left the padding in there.
Old Mar 24, 2014 | 06:46 PM
tjvz28's Avatar
Car: 91 Camaro Z28
mine was falling apart I guess I will through back in there
I find it weird that it bolted right up in there with not drilling hole on top of pedal assembly
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
