700r4 woes
Old Apr 17, 2014 | 07:30 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
700r4 woes
Anyways, My 700R4 Grinds when going into reverse from park. Get into the street, put it into drive and and then it clucks and the tires chirp (foot off gas peddle, on brake), worse when going from Park to Drive. If I drive next to a wall or something I can hear the trans faintly grind through first and second. Fluid is clear red, smelly but not burned smelly.
The other night I made the brave decision to race the wife (late night, sitting at a red light). It launched off the line, but at about 30MPH it couldnt decide what gear it wanted to be in, RPMs all over the place, and then i could smell it for about 4 blocks. Race lasted less than a block. I won
Car still drives but it makes louder grinding and clunking noises. Can it be fixed or is it a total rebuild?
I hate to take it to a shop because they will charge to tear it down for examination, and if I dont give in to there demands I will have to tow it home with all the bits in the trunk.
Old Apr 17, 2014 | 08:38 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Re: 700r4 woes
Drop the pan, If there is metal in it then it will need to be rebuilt anyway.
Old Apr 17, 2014 | 10:33 AM
sorrys70's Avatar
Re: 700r4 woes
That thing sounds beyond shot, i would go to the scrap yard pick up a used one for 300 bucks and call it a day .keep the old one and have it rebuilt or if your brave enough buy a rebuild kit and tackle if yourself ,
Old Apr 17, 2014 | 11:27 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: 700r4 woes
id go pick up a cheap one from a jy or craigslist or something, throw that in then buy a rebuild kit with upgrades that you may want and learn from it. doesnt sound like a very easy fix.
Old Apr 18, 2014 | 12:08 AM
Veaceonee's Avatar
Re: 700r4 woes
There is only one 3rd gen in the JY, a bunch of 4th gen camaros, all V6 cars.
Old Apr 18, 2014 | 09:05 AM
sorrys70's Avatar
Re: 700r4 woes
Gm used 700r4s in everything . Vans trucks all kinds of stuff. If you walk in that junk yard and they dont have a 700r4 for a v8 you should tell them they are a disgrace ! ; )
Old Apr 18, 2014 | 11:17 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Re: 700r4 woes
Just pick one with the same tail housing length. Swap housing.
Old Apr 18, 2014 | 11:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700r4 woes
Get a used 700R4 from anything but a Corvette, or 4x4 or diesel pickup.
Old Apr 18, 2014 | 11:26 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Re: 700r4 woes
if you were closer to michigan i have one id offer up
Old Apr 18, 2014 | 12:26 PM
Veaceonee's Avatar
Re: 700r4 woes
I have a theory about junkyard parts. They are there for a reason. How can I tell if the trans is good or not?
Old Apr 18, 2014 | 12:51 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: 700r4 woes
ID a donor that is wrecked. Chances are it was running fine up until it found it's home in the JY.
Otherwise good clean fluid, and if you can pull the pan-lack of friction material.
Old Apr 18, 2014 | 01:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 700r4 woes
Get a rebuilt then.
Old Apr 18, 2014 | 04:40 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: 700r4 woes
Make sure the case is 89.and later.....=larger input shaff
I think ya have a broke sprag. .
Old Apr 23, 2014 | 11:52 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Re: 700r4 woes
Amongst other things.
Old Apr 23, 2014 | 02:43 PM
Veaceonee's Avatar
Re: 700r4 woes
Took it to the trans shop here in town. they said the grinding is the Planetary gears, and the 3-4 Clutch pack is gone. Going down for a swap on friday.
Old Apr 24, 2014 | 05:15 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 700r4 woes
buy NOTHING that doesent have a warranty.but really its better in the long run to just have the one you have rebuilt
Old Apr 24, 2014 | 07:24 PM
Veaceonee's Avatar
Re: 700r4 woes
Going into the shop tommorrow. Cant wait to have a reliable car again.
Old Apr 24, 2014 | 07:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 700r4 woes
http://www.700r4l60e.com/
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
