Hard shift into drive
Car: 1986 Iroc-Z
Engine: Swapped 350
Transmission: 700r
I have a '86 iroc with a swapped 350 and a 700r4 auto trans in it. When I shift from park to drive it jerks itself hard into drive after that it shifts through the gears no problem smooth as can be. What could it be and how to fix it?
Re: Hard shift into drive
Trans mount could be bad,just had my car on a lift for inspection and the mount has a lot of play in it,that will be next on the list to replace.
It bangs pretty hard into gear too.
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
^^ +1, I've had this problem a couple times, its always been my trans mount.
Car: 85' Firebird TransAm
Engine: 305ci TPI 5.0L
Axle/Gears: Posi 9 bolt differential 3.27
My car does this too! In reverse or OD, 1st and 2nd are smooth as well as normal driving, I always thought it could be the shift cable needing adjustment but the tranny mounts is definitely something to consider, My grandpa's 91' Silverado 2500 also does this too it has 250/xxx miles, nothing has blown up yet!
Car: 1983 Z28
Engine: 385 Fastburn
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I know if you dont have the low/reverse check ball in the capsule it will slam into gear, and how is the idle set cause if its not adjusted like to high it will slam into gear.
maroe624
Apr 16, 2017 08:29 AM
