Pictures of every component of a 700R4 ...
Old Apr 19, 2014 | 08:55 AM
OrangeBird's Avatar
Car: 1989 Firebird
Just for the sheer fun of it , and for the fact that I've never seen every component of one of these transmissions myself , I decided to take a high mileage but still functional 700R4 totally apart and take pictures of every component with a standard sized BIC lighter in each photo for size scale . I am hoping this thread will serve as reference for anyone who is wondering or needs to know exactly what each component looks like . Questions and comments are of course welcome and it's quite likely that I'll have a few questions myself as my primary training is in Aircraft Maintenance and not Automatic Transmissions . At this point I have managed to totally disassemble most of the major functional assemblies down to the component level . There will be several components that I will not know the names of or exact functioning of and expert help will be most welcome in those areas . So far , I have found four separate multiple plate clutches , one Band , two planetary gear sets , and a whole bunch of control components in the form of Valve body , Accumulators , Servo/pistons , and some other neat stuff . One last thing to note is that by the time of the photographs the components were cleaned up somewhat and most of the replaceable seals/gaskets are not included in the shots (cleaning lady got to the shop before I got the idea to do this )
So , I guess we'll start small here , and show the Governor . As we all know , this lives behind the tin metal cap on the driver's side just in front of the tailshaft . The cover for this was SO rusty that it literally crumbled upon removal and so is not shown . After removing the cover this just pulls out with a slight twist to unmesh the gears .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-4.jpg   Pictures of every component of a 700R4 ...-700r4-5.jpg   Pictures of every component of a 700R4 ...-700r4-6.jpg
Old Apr 19, 2014 | 08:59 AM
OrangeBird's Avatar
Car: 1989 Firebird
pictures of every component of a 700R4 ...
More Governor . My next post will contain the VSS , and so on untill we have shown every component .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-3.jpg   Pictures of every component of a 700R4 ...-700r4-7.jpg
Old Apr 19, 2014 | 09:04 AM
OrangeBird's Avatar
Car: 1989 Firebird
The VSS in all it's glory . This also lives on the driver's side of the transmission and is on the Tailshaft a few inches behind the Governor . I have pictured both drive and driven gears , as well as the clip that holds the drive gear to the output shaft ......
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-8.jpg   Pictures of every component of a 700R4 ...-700r4-9.jpg   Pictures of every component of a 700R4 ...-700r4-10.jpg
Old Apr 19, 2014 | 09:08 AM
OrangeBird's Avatar
Car: 1989 Firebird
Last one of the VSS , this one with the driven gear slid off of the VSS' input shaft .
PS , In case anyone is wondering why I'm only putting 3 pics per post is that the uploader tells me that 3 is the maximum number of pics I can post ...
Anyway , Stay tuned for further updates
Old Apr 19, 2014 | 05:19 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: PARADE REST !!!!! Pics of EVERY component of a 700R4 !!
Great idea for a thread. Keep going!
If those who know auto trannys could also comment on what needs replacing or servicing, that would be great too!
Old Apr 19, 2014 | 06:31 PM
OrangeBird's Avatar
Car: 1989 Firebird
Thank You StealthTA , I appreciate the kind words for our lil ol transmission thread here . I just want to see one thread where folks can go to reference any part of our beloved (or sometimes love to hate) 700R4 . And yes , the more comments from those in the know the better , I like to think of this as "our" thread and not "my" thread
Oh , I probablly should have revealed in my opening post that this 700R4 is a 1988 model and does have the metal tubing running from the pump to the aux valve body (I'm told earlier models of the 700R4 did not have this tube) ..
SOoo Moving right along with the slideshow we will now show the entire electrical circuit contained within the transmission . There are really only two functional components , the T.C.C. solenoid and the 4th gear pressure switch . Those two , along with some wire , a connector designed to pass through the transmission outer case , and a plastic wire loom to keep things tidy are all that's in there . The solenoid , as one would figure , engages the Torque Converter Clutch to lock up the converter by opening a fluid passage , and the switch is there to tell the E.C.M. that the transmission is in fourth gear so as to allow the lockup to happen . (this also happens from fluid pressure which is monitored at the valve body ) .....
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-12.jpg   Pictures of every component of a 700R4 ...-700r4-13.jpg   Pictures of every component of a 700R4 ...-700r4-14.jpg
Old Apr 19, 2014 | 06:43 PM
OrangeBird's Avatar
Car: 1989 Firebird
Ok , next up we have the Band and it's apply servo with it's cover . This is on the passenger's side and the servo is removable without going into the transmission , while the band itself does require removing the pump . This servo is the one that folks change out with a Corvette servo for more holding power .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-15.jpg   Pictures of every component of a 700R4 ...-700r4-16.jpg   Pictures of every component of a 700R4 ...-700r4-17.jpg
Old Apr 19, 2014 | 06:45 PM
OrangeBird's Avatar
Car: 1989 Firebird
This post originally had a photo that was showing a mistaken placement of the servo and band . I am replacing the bad photo with a photo of some of the external hardware .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-misc..jpg
Old Apr 21, 2014 | 11:20 AM
OrangeBird's Avatar
Car: 1989 Firebird
Ok , next up are 3 accumulator assemblies . I find reference on line to "1-2" and "3-4" accumulator but no identification of which is which . Also , what the third one is for . The third one that has no housing is located under the valve body separator plate and it's housing is actually the transmission case .
Can any 700R4 savvy folks further identify these three accumulators ?
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-19.jpg   Pictures of every component of a 700R4 ...-700r4-20.jpg
Old Apr 21, 2014 | 04:44 PM
OrangeBird's Avatar
Car: 1989 Firebird
Just to see if we can jog anyone's memory , here's a shot of where that third accumulator is located in the case .
Anyone got anything on this ???
Old Apr 21, 2014 | 07:24 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
In your photos from left to right:
1-2 accumulator
3-4 accumulator
Aux Valve Body
Don't mix up the springs.
If you're rebuilding this unit, check for wear at the piston pin holes. Better yet, just replace all the pistons and pins.
Old Apr 21, 2014 | 07:29 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
This is where the 3-4 accumulator lives. Fit the pin, then the piston (legs towards the spring) and then the spring.
Old Apr 21, 2014 | 07:35 PM
StealthESW's Avatar
Car: '84 Berlinetta T-Top
Engine: 305 V8 LG4
Axle/Gears: 3.08
I think the aux accumulator is for when you shift from park to drive or drive to reverse or park to reverse or so. The aux acc is the one that has a seperate body in the upper right of your pics. If I remember correctly.
Old Apr 21, 2014 | 08:38 PM
OrangeBird's Avatar
Car: 1989 Firebird
Hi Paulo and Eric ,
Thank you both for your responses ! I really appreciate the identification of these three and to show my appreciation I'll jump into some REAL Gearhead territory now ... Yep , just HOW can we call ourselves Gearheads with no gears yet showing ? Well , to rectify that I now present the rear planetary set in all it's glory .
PS , to answer Paulo's question , No sir I have no plans of rebuilding this transmission , this is simply an exercise to see the parts for myself up close , and to show all my fellow third gen owners what the insides of one of these looks like . If the transmission in my car were to ever need to be rebuilt I'd buy one of those book/video tutorials and rebuild kit and rebuild the one in the car . I am carefully cleaning and boxing up each of these parts after their photoshoot and I will keep them as possible spares in the event I ever need them .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-24.jpg   Pictures of every component of a 700R4 ...-700r4-25.jpg   Pictures of every component of a 700R4 ...-700r4-26.jpg
Old Apr 21, 2014 | 08:39 PM
OrangeBird's Avatar
Car: 1989 Firebird
And two more of the Rear planetary gear set .....
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-27.jpg   Pictures of every component of a 700R4 ...-700r4-28.jpg
Old Apr 22, 2014 | 05:43 PM
OrangeBird's Avatar
Car: 1989 Firebird
Finally found some obvious wear to show everyone !
This is the metal separator plate that sits between the valve body and the transmission case . It appears that several of the small steel check ***** have worn elongated grooves into the metal that they ride against . Now remember , this transmission shifted fine and so I don't think any of these had gotten to the point of jamming or sticking . Yet . I wonder how much longer it would have been till there was SO much wear that the shifting would be compromised ?
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-29.jpg   Pictures of every component of a 700R4 ...-700r4-30.jpg   Pictures of every component of a 700R4 ...-700r4-31.jpg
Old Apr 23, 2014 | 05:39 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Pics of EVERY component of a 700R4 !!
No one with any comments on the worn valve body separator plate ?
Ok then , on with the pictures ...
Next up we have the internal shifting linkage . This is everything that moves inside the transmission when the shift lever in the car is moved except the actual valve in the valve body (that valve will be shown later with the rest of the valve body) . The detent spring and park pin guide bracket are shown also .
Old Apr 23, 2014 | 11:15 PM
StealthESW's Avatar
Engine: 305 V8 LG4
Axle/Gears: 3.08
Those worn out holes might be repairable. You could look into the Fitzall VB101 kit. (If you want to try to fix the plate.)
This is what it looks like, you get 5 seats and clips in the kit.
You drill the hole out to like 1/4 inch and insert the part on the right from the case side of plate and then slip the retaining clip on it from the valve body side. Proper install instruction come with the kit.
Old Apr 23, 2014 | 11:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
This is a common problem.
TCI sells a hardened plate which is supposed to be a bit more wear resistant. Last time I checked their plate is the same price as a new, OEM un-hardened plate.
I would just go with a new OEM plate and Torlon check *****.
http://www.trutechtrans.com/Sonnax-10000-08-Basket.html
Old Apr 24, 2014 | 07:41 AM
stealtht/a's Avatar
Re: Pictures of every component of a 700R4 ...
Great info guys, this is just the kind of guide I was hoping for.
Old Apr 24, 2014 | 05:47 PM
OrangeBird's Avatar
Car: 1989 Firebird
Thank You both StealthESW and Paullo for the great suggestions of repairs/replacement of the damaged valve body separator plate . I really appreciate the input and it's nice to have options when it comes to fixing these things .
I'd like to take a minute here and go somewhat off topic for a bit , if it's Ok with all of you . A nice polite gentleman has PMed me in inquiry as to the 41 tooth gear on my VSS . This gent seems to be having a really hard time finding one and I was hoping someone out here might have a spare one they could sell to him ? My car is a V6 and also my spare transmission that I've taken apart is from a V6 as well . It seems the V6 cars came stock with a 3:45 rear ratio and this is where he needs the 41 tooth (maybe he has swapped a 3:45 rear into his V8 car ?) . Anyway , if anyone has one please PM me and I'll forward your contact info to him .
Ok , back to the photos . I have not shown any hardware in the form of bolts since there really isn't all that much remarkable about most of em . The exception , in my opinion , are the 7 bolts that hold the pump onto the case . These bolts have their heads machined to accept O rings where the bolt head meets the pump housing . Interesting ... I wonder if the bolts were a problem leakage spot and thus the O rings ? And do other transmissions have similarly machined bolts holding their pumps on ?
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-33.jpg   Pictures of every component of a 700R4 ...-700r4-34.jpg
Old Apr 25, 2014 | 12:40 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
I don't know if leakage around the pump bolts was an issue (I doubt it).
If you have the pump off the case, take a look at the pump gasket. Notice that some holes in the gasket don't fully encircle some of the pump mounting holes. Makes for a nice leak path if you forget the o-rings.
I don't have an answer for why the gasket doesn't go around each mounting hole. My guess is that it's used as a visual indicator; these holes in the gasket are supposed to line up around a threaded hole.
Old Apr 25, 2014 | 07:49 PM
OrangeBird's Avatar
Car: 1989 Firebird
Hi Paulo ,
I do have it all apart and I did look at the pump to case gasket surface . It seems the gasket's job is to keep the high pressure fluid from leaking between the pump housing on it's way to the fluid passages in the transmission case . The large O ring around the pump's perimeter seems to keep the fluid from leaking out of the case as the pump to case fitting has fluid behind it as well . When I get the pump photos up I'll be sure to get some of where the pump sits into the case also .
Ok , anyway , the next pics are more specialized hardware type parts in the form of retaining rings and thrust washers and thrust bearings . There is usually some spring pressure involved in removing some of these retaining rings and in fact I managed to not only drop but also step on one of the clutch spring sets which I'll show in this set of pictures as well . This spring set and the governor cover were the only two things destroyed while taking this 700R4 apart , I'm happy to report .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-35.jpg   Pictures of every component of a 700R4 ...-700r4-36.jpg   Pictures of every component of a 700R4 ...-700r4-41.jpg
Old Apr 26, 2014 | 06:06 PM
OrangeBird's Avatar
Car: 1989 Firebird
Here are two parts that I remember removing , but I can't quite remember from where . One is a retainer of some sort and one is a small brown gear .
Any answers of what these parts are and what they do would be most welcome
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-37.jpg   Pictures of every component of a 700R4 ...-700r4-38.jpg   Pictures of every component of a 700R4 ...-700r4-39.jpg
Old Apr 27, 2014 | 09:50 PM
OrangeBird's Avatar
Car: 1989 Firebird
Ok then , , Moving along here , we have the 3/4 clutch release springs and the tailshaft housing . I tried to get as best of a look as possible at the bushing that the driveshaft yoke rides in , and am kinda surprised at how relatively little contact area there is with the yoke and bushing (it seems like just over an inch of contact , I expected a couple to maybe few inches of bushing in contact with the yoke ???)
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-40.jpg   Pictures of every component of a 700R4 ...-700r4-42.jpg   Pictures of every component of a 700R4 ...-700r4-43.jpg
Old Apr 27, 2014 | 10:24 PM
StealthESW's Avatar
Engine: 305 V8 LG4
Axle/Gears: 3.08
The metal clip is actually the anti-clunk spring. It sits on a little ridge in the case and the seprator plate sort of sits on it.
The small gear is actually a seal that goes between the input shaft and the output shaft.
Old Apr 27, 2014 | 10:32 PM
StealthESW's Avatar
Engine: 305 V8 LG4
Axle/Gears: 3.08
And a close up detail of the ball and socket of the servo and band .....
Your photo is showing the servo pin connection incorrectly. The servo pin engages the bracket on the opposite end of the band. The case anchor pin is what contacts the hole in the flat bracket on the band.
Old Apr 28, 2014 | 09:38 AM
OrangeBird's Avatar
Car: 1989 Firebird
Thank You Stealth ESW for the correction ! If any of my photos are incorrect I really appreciate being told so that we don't have bad information .
Here's the thing ..... It's been a while since I took this apart and because this is the first time I've ever taken one of these this far apart , I have to rely on my recollections of where exactly everything was . Up till now I had previously done such things as new pump gaskets and maybe a rear seal or two but this is as deep as I've ever seen into any automatic transmission . This sat around a month or few before I got the idea to show pictures of all of it and that's why if something isn't dead obvious there is the chance I may get it wrong .
Old Apr 28, 2014 | 09:44 AM
OrangeBird's Avatar
Car: 1989 Firebird
And also . Is the "case anchor pin" the thing I have pictured here with the valve body and it's check Ball.s ?
I really DO appreciate the help in identifying these parts
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-53.jpg   Pictures of every component of a 700R4 ...-700r4-54.jpg   Pictures of every component of a 700R4 ...-700r4-57.jpg
Old Apr 28, 2014 | 03:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Anti-clunk spring and its location. It's wedged between the case and low/reverse clutch support (center support) and is held in with the low/reverse support retainer ring.
Input shaft to output shaft seal and its location in the input housing.
Old Apr 28, 2014 | 03:29 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
If you ever think of putting it back together, get one of these depending on the model year of your transmission. Well worth the money.
ATSG General Motors THM 700-R4 Techtran Manual, 1982-1986 (4L60): Automatic Transmission Service Group: Amazon.com: Books ATSG General Motors THM 700-R4 Techtran Manual, 1982-1986 (4L60): Automatic Transmission Service Group: Amazon.com: Books
ATSG THM 700-R4 (4L60) 1987-1993 Techtran Manual: Robert D. Cherrnay: Amazon.com: Books ATSG THM 700-R4 (4L60) 1987-1993 Techtran Manual: Robert D. Cherrnay: Amazon.com: Books
Get the update edition as well.
ATSG GM 700R4 4L60 Techtran Transmission Rebuild Manual (Supplemental) (Update Handbook 1982-1993): Automatic Transmission Service Group: Amazon.com: Books ATSG GM 700R4 4L60 Techtran Transmission Rebuild Manual (Supplemental) (Update Handbook 1982-1993): Automatic Transmission Service Group: Amazon.com: Books
Old Apr 29, 2014 | 08:52 AM
OrangeBird's Avatar
Car: 1989 Firebird
Thank You again to Paulo for the parts identification and the links to the rebuild manuals ! If I ever do rebuild one of these I had planned to get books of the exact kinds in Paulo's links and maybe even one of those video tutorials as well . Course , at my age and health status , the transmission in my car may yet outlive me , in which case it'll be the next owner's responsibility
So , Ill now run through a bunch more photos of parts I've got , starting with a few more of the valve body and showing the 9 check ***** . Eight of them seem to be the same size and one is larger and doesn't seem to be made out of the same metal as the other 8 . (the 8 look shiny , almost chrome like , wheras the one bigger one looks dull grey)
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-55.jpg   Pictures of every component of a 700R4 ...-700r4-56.jpg   Pictures of every component of a 700R4 ...-700r4-58.jpg
Old Apr 29, 2014 | 08:58 AM
OrangeBird's Avatar
Car: 1989 Firebird
Here are three pictures of what is called the "Sun gear reaction shell" in advertising that I have found . This part seems to be weak enough that the automotive aftermarket has manufactured a more robust copy that they sell as "The Beast" , gotta love the marketing there , eh ?
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-59.jpg   Pictures of every component of a 700R4 ...-700r4-60.jpg   Pictures of every component of a 700R4 ...-700r4-61.jpg
Old Apr 29, 2014 | 09:07 AM
OrangeBird's Avatar
Car: 1989 Firebird
And , while were in the neighborhood , we might as well get the front planetary gear set up here now (the rear set was shown in post #14)
There is a one way clutch built into the first hub that is shown removed in the photos . By one way I mean that it will "free wheel" in one direction and spin both the inner and outer sections in the other direction . I have heard such mechanism referred to in the past as an "overrunning clutch" , but I have not found that term being used for this unit . I have found the term "Sprag" and am wondering if this is what's being referred to ?
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-48.jpg   Pictures of every component of a 700R4 ...-700r4-49.jpg   Pictures of every component of a 700R4 ...-700r4-50.jpg
Old Apr 29, 2014 | 09:08 AM
OrangeBird's Avatar
Car: 1989 Firebird
More front planetary set ...
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-51.jpg   Pictures of every component of a 700R4 ...-700r4-52.jpg
Old Apr 29, 2014 | 04:15 PM
StealthESW's Avatar
Engine: 305 V8 LG4
Axle/Gears: 3.08
Yes. The case anchor pin is in these photos.
This is a great thread. I just finished a '92 4L60 rebuild for my '84 Berlinetta. This thread is giving me flashbacks.
Old Apr 29, 2014 | 07:40 PM
OrangeBird's Avatar
Car: 1989 Firebird
Hi StealthESW , Thank You for the compliment . I am hoping to get this thread made into a sticky after I get all of the pictures posted up . I really hope the pictures prove helpful to folks who are wondering what the parts look like but have never had the chance to see them .
Hey , speaking of pictures , here's some of the front drum that the band grabs on to . The end of this drum is the first thing that's visible inside the transmission when the pump is removed . It will , of course , have the input shaft sticking out of it , which will be shown later along with the drum the input shaft is pressed into , which fits behind/inside this one . The piston shown was affixed with one REALLY strong spring set and so I imagine it took quite some fluid pressure to overcome those springs to move the piston ?
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-62.jpg   Pictures of every component of a 700R4 ...-700r4-63.jpg   Pictures of every component of a 700R4 ...-700r4-64.jpg
Old Apr 29, 2014 | 07:43 PM
OrangeBird's Avatar
Car: 1989 Firebird
And while we're on big pistons , here's two from the next drum I will show (the input drum , the one with the input shaft pressed into it)
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-44.jpg   Pictures of every component of a 700R4 ...-700r4-46.jpg
Old Apr 29, 2014 | 08:06 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
question is will you remember where all these parts go when it comes time to putting it back together
Old Apr 29, 2014 | 10:19 PM
StealthESW's Avatar
Engine: 305 V8 LG4
Axle/Gears: 3.08
He has a book to help with that.
Old Apr 30, 2014 | 02:13 PM
OrangeBird's Avatar
Car: 1989 Firebird
Hi 90camaro355rs ,
Your question is a valid one for any automotive hobbyist , whether age challenged like me or not . There are SO many pieces of this thing that if I ever were planning on rebuilding it I would have disassembled it in a much different manner . This 700R4 is not the one from my car but is a high mileage spare that came along with the car when I got it , In fact I got both a spare 700R4 and a spare engine of one year earlier than my car (my car is an 89 and the spares are from 88) . Since my car has barely 80K miles and runs perfectly and I have about 210K miles on ME I'm kinda hopin the one in the car outlives me . If I am forced to rebuild any 700R4 it will be the one in the car with this one used as reference and possible spare parts . Any transmission that anyone plans on RE assembling had best be taken apart in a proper "dis assembly sequence" with ALL parts identified as to placement , fitment , and any other notes/photos that may be needed to insure every last piece goes back in properly where it was before removal . Not to mention I would also , of course , obtain such material as Paullo provided in his post # 31 , and rely on the helpful advice and suggestions of guys like StealthESW , folks who have seen this and done this already
Ok , So , next up is the input drum/input shaft which have been emptied of all pistons , springs , and clutch parts . The last 4 components from the bottom of the drum are pictured also . (clutches to follow soon)
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-80.jpg   Pictures of every component of a 700R4 ...-700r4-81.jpg   Pictures of every component of a 700R4 ...-700r4-82.jpg
Old Apr 30, 2014 | 02:24 PM
  #42
OrangeBird's Avatar
Car: 1989 Firebird
And one last one of Input drum parts , along with two of the output shaft .
For any future reference , although the output shaft housing can be removed with the transmission still bolted to the engine , the output shaft itself is held in by a snap ring that is not reachable till you've seen such components as the input drum and others removed .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-83.jpg   Pictures of every component of a 700R4 ...-700r4-67.jpg   Pictures of every component of a 700R4 ...-700r4-68.jpg
Old May 2, 2014 | 08:57 PM
  #43
OrangeBird's Avatar
Car: 1989 Firebird
An interesting thing happened when I looked at the clutches . What I thought were four are actually five with the fifth being a two friction plate unit that rides on the back of a larger clutch set .
In the first picture you can see the stacks of clutch sets just as I removed them . In the second , you can see where I've fanned them out to get a look at the friction and steel plates .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-69.jpg   Pictures of every component of a 700R4 ...-700r4-70.jpg
Old May 2, 2014 | 09:04 PM
  #44
OrangeBird's Avatar
Car: 1989 Firebird
In this shot , you can see the two different kinds of friction plates I found in the forward stack . This is the clutch set that was top left of the above shots . I tried to get a good close up of the two different kinds friction material because for a high mileage unit I think the friction plates look great .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-77.jpg   Pictures of every component of a 700R4 ...-700r4-78.jpg   Pictures of every component of a 700R4 ...-700r4-79.jpg
Old May 2, 2014 | 11:05 PM
  #45
StealthESW's Avatar
Engine: 305 V8 LG4
Axle/Gears: 3.08
The two small friction plates are overrun clutches, they are applied when you release the gas pedal and coast (engine breaking).
Old May 3, 2014 | 01:05 PM
  #46
OrangeBird's Avatar
Car: 1989 Firebird
Thank You StealthESW . It's funny , I did find mention of the overrun clutch in some of the reference material I have been using but had mistakenly thought it was talking about the one way hub I found on the front planet set . Then when I went to take these pictures and found the extra clutch I was curious enough to read some more and found that it is called as you said it , the overrun clutch .
Also , I would like to Thank AaronIROCZ for making this thread a sticky . The TGO forum has given me SO much great info and has such great people that I wanted to do something helpful for all the TGO members in return
Ok , Time for some more pictures . Here we have the pump just as it comes out of the front of the case . The tubing that feeds fluid to the aux valvebody is shown in the photo as well . I have pulled out the fluid strainer to show and to be honest I was really surprised when I read about this "hidden" filter . I had always believed there to be only one thing filtering the fluid in an automatic transmission , that being the one in the pan that picks up the fluid to feed the pump . This strainer from what I read is in the outlet side of the pump and of course due to location isn't a regularly serviced item so seldom seems to receive much mention .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-85.jpg   Pictures of every component of a 700R4 ...-700r4-86.jpg   Pictures of every component of a 700R4 ...-700r4-87.jpg
Old May 3, 2014 | 01:10 PM
  #47
OrangeBird's Avatar
Car: 1989 Firebird
And one last shot of the strainer .
Old May 4, 2014 | 01:13 PM
  #48
OrangeBird's Avatar
Car: 1989 Firebird
One last thing to mention about the pump . Every so often , someone makes the mistake of bolting the engine and transmission together without having the torque converter fully seated into place . This can result in the drive tabs being sheared off of the pump and of course the pump being rendered inoperative . I did not disassemble the pump during this disassembly but still wanted to show what gets broken if this happens . So , I borrowed a picture of the pump opened up and the parts that get broken are the little tabs at the "6" and "12" oclock positions in the middle opening of the rotor .
I have added a shot of the neck on the torque converter that keys into the pump's rotor drive tangs .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-89.jpg   Pictures of every component of a 700R4 ...-700r4-92.jpg
Old May 4, 2014 | 01:23 PM
  #49
OrangeBird's Avatar
Car: 1989 Firebird
Here's the very last piece that comes out of the case . This is the low/reverse piston and it's return springs and C clip . I still have some pictures of the empty case left to show which I'll post soon .
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-90.jpg   Pictures of every component of a 700R4 ...-700r4-91.jpg
Old May 6, 2014 | 08:01 PM
  #50
OrangeBird's Avatar
Car: 1989 Firebird
Some shots of the case ...
Attached Thumbnails Pictures of every component of a 700R4 ...-700r4-94.jpg   Pictures of every component of a 700R4 ...-700r4-95.jpg   Pictures of every component of a 700R4 ...-700r4-96.jpg
