T56 reverse lock out somoco how to wire??
Old May 1, 2014 | 06:22 PM
tjvz28's Avatar
Car: 91 Camaro Z28
im doing t56 conversion on 91 Camaro that had the 700 r4.
I have the sgi5 box, the somoco unit says it taps off vss. how does this work the vss sensor is different than 700 r4. could someone tell me how to hook this up please
Old May 1, 2014 | 08:48 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: T56 reverse lock out somoco how to wire??
If you go on their website you can download the instructions and see for yourself it's pretty easy
Old May 3, 2014 | 04:53 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I tapped mine off the brake switch. When I apply the brake it unlocks reverse.
Old May 3, 2014 | 05:16 PM
572_Rat's Avatar
Only problem is if you are down shifting and need to hit the brakes, it would allow you to push it into reverse
Old May 3, 2014 | 08:24 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Why would you down shift to the right? Reverse is way over there and the last upper most gear to the right. I don't even think it would engage if that did happen.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
