Axle Codes
Old May 10, 2014 | 10:39 PM
StealthESW's Avatar
Car: '84 Berlinetta T-Top
Engine: 305 V8 LG4
Axle/Gears: 3.08
Axle Codes
Axel codes can be found on the front of the passenger side axle tube. The first three characters of the code can be decoded as referenced in the lists below.
Code:
1982
Axle Code           Gear Ratio           Type
2JE                 2.73                 Standard
2JG                 3.08                 Standard
2JH                 3.23                 Standard
2JJ                 3.42                 Standard
2JR                 3.42                 Posi-Trac
2JW                 2.73                 Posi-Trac
2JX                 2.93                 Posi-Trac
2JY                 3.08                 Posi-Trac
2JZ                 3.23                 Posi-Trac
2KE                 2.73                 Standard
2KF                 2.93                 Standard
2KG                 3.08                 Standard
2KH                 3.23                 Standard
2KJ                 3.42                 Standard
2PE                 2.73                 Standard
2PW                 2.73                 Posi-Trac
2PX                 2.93                 Posi-Trac
2PY                 3.08                 Posi-Trac
2PZ                 3.23                 Posi-Trac
Code:
1983
4JF                 2.93                 Standard
4JG/5JG             3.08                 Standard
4JH/5JH             3.23                 Standard
4JJ/5JJ             3.42                 Standard
4JK/5JK             3.73                 Standard
4JQ/5JQ             3.73                 Posi-Trac
4JR/5JR             3.42                 Posi-Trac
4JX/5JX             2.93                 Posi-Trac
4JY/5JY             3.08                 Posi-Trac
4JZ/5JZ             3.23                 Posi-Trac
5KM                 3.73                 Standard
5KN                 3.73                 Posi-Trac
5PN                 3.73                 Posi-Trac
4PQ/5PQ             3.73                 Posi-Trac
4PX/5PX             2.93                 Posi-Trac
4PY/5PY             3.08                 Posi-Trac
4PZ/5PZ             3.23                 Posi-Trac
Code:
1984
6EA                 3.42                 Standard
6EF                 3.42                 Posi-Trac
6EP                 3.42                 Posi-trac
6JG                 3.08                 Standard
6JH                 3.23                 Standard
6JJ                 3.42                 Standard
6JK                 3.73                 Standard
6JQ                 3.73                 Posi-Trac
6JR                 3.42                 Posi-Trac
6JY                 3.08                 Posi-Trac
6JZ                 3.23                 Posi-Trac
6KM                 3.73                 Posi-Trac
6PM                 3.73                 Standard
6PQ                 3.73                 Posi-Trac
6PY                 3.08                 Posi-Trac
6PZ                 3.23                 Posi-Trac
Code:
1985
8JA                 3.08                 Standard
8JB                 3.23                 Standard
8JC                 3.42                 Standard
8JD                 3.73                 Standard
8JP                 3.08                 Posi-Trac
8JQ                 3.23                 Posi-Trac
8KA                 3.42                 Standard
8KB                 3.73                 Standard
8KR                 3.08                 Standard
8PP                 3.08                 Posi-Trac
8PQ                 3.23                 Posi-Trac
8PR                 3.42                 Posi-Trac
8PS                 3.73                 Posi-Trac
Code:
1986
2HC                 3.73                 Standard
2HD                 2.73                 Standard
2HG                 3.23                 Standard
2HH                 3.42                 Standard
2HL                 3.42                 Standard
2HM                 3.73                 Standard
2HP                 2.73                 Standard
2HS                 3.73                 Posi-Trac
2HT                 2.73                 Posi-Trac
2HV                 2.73                 Posi-trac
2HY                 3.23                 Posi-Trac
Code:
1987
2HA                 3.23                 Standard
2HL                 3.42                 Standard
2HP                 2.73                 Standard
2HQ                 3.23                 Posi-Trac
2HT                 2.73                 Posi-Trac
4EU                 3.27                 Posi-Trac Borg-Warner
4EW                 3.45                 Posi-Trac Borg-Warner
4HB                 3.08                 Posi-Trac
4HD                 2.73                 Posi-Trac
4HF                 3.08                 Posi-Trac
4HY                 3.23                 Posi-Trac
Code:
1988 and 1989
6HT                 2.73                 Posi-Trac
6HP                 2.73                 Standard
6HB/6HF             3.08                 Posi-Trac
6HK                 3.08                 Standard
6HL                 3.42                 Standard
6HQ/6HJ             3.23                 Posi-Trac
GH3                 2.77                 Posi-Trac Borg-Warner
GW6                 3.27                 Posi-Trac Borg-Warner
GM3                 3.45                 Posi-Trac Borg-Warner
Code:
1990
8HP                 2.73                 Standard
8HT/8RC             2.73                 Posi-Trac
8HK                 3.08                 Standard
8HF/8HB             3.08                 Posi-Trac
2PM/2PN             3.23                 Posi-trac
8HL                 3.42                 Standard
9EQ                 3.27                 Posi-Trac Borg-Warner
9ER                 3.45                 Posi-Trac Borg-Warner
Code:
1991 and 1992
8H3                 3.23                 Standard
8HE                 2.73                 Posi-Trac
Old May 11, 2014 | 12:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Axle Codes
There is a link in the 10 bolt faq pointing to the axle codes
https://www.thirdgen.org/forums/tran...-10-bolts.html
Old May 11, 2014 | 01:51 AM
StealthESW's Avatar
Engine: 305 V8 LG4
Axle/Gears: 3.08
Re: Axle Codes
Well, this is easier to find now.
6speedIROC
16
Mar 15, 2023 08:33 PM
db057
Jan 10, 2020 08:55 PM
Numbah-1
Sep 20, 2015 09:31 AM
dbrochard
Sep 7, 2015 09:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
