torque arm bolts
Old May 11, 2014 | 05:03 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
torque arm bolts
Got new torque arm bolts from Spohn.
Could use accurate torque specs, and whether to use Locktite, antisieze, or nothing.
Also, what torque reduction with any lube?
Iirc torque should be around 102 ft. lbs dry. No way to torque the nut as far as I can see so it would be bolt head torque.
Any help would be appreciated.
Thanks in advance!
Old May 11, 2014 | 05:24 PM
StealthESW's Avatar
Car: '84 Berlinetta T-Top
Engine: 305 V8 LG4
Axle/Gears: 3.08
Re: torque arm bolts
Torque arm bracket to transmission bolts should be 31 Ft-lbs.
Torque arm to rear axle bracket bolts should be 100 Ft-lbs.
No locktite. No anti-seize.
Old May 11, 2014 | 06:16 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
That will work,I had read 102 for, the big ones in the Haynes manual. The bolts go through the bottom an the torque wrench goes on the bolt head and not the nut though, right?? Some bolts require torque at the nut to prevent twist on the bolt shaft.
If that was the case, the rear would have to come out again. Or at least be dropped a mile to get the long bolts in.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
