T56 driveshaft pics?
Old May 18, 2014 | 09:55 AM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I was wondering if anyone has a pic of how far their driveshaft goes into their t56? I was looking at mine and I think it might be too short. I had it shortened when I installed the ls t56. Now I am thinking I might have measured wrong. It works fine but there's like an inch of shaft showing between the dust seal And the yoke.
Old May 19, 2014 | 04:33 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: T56 driveshaft pics?
Unless you put an LS T56 onto a Gen I/II block you should have used a stock length driveshaft. So it's probably short by however much you shortened it.
Old May 19, 2014 | 08:06 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Take measurements.
Determine how far into the tailhousing bushing the yoke is inserted. That bushing is an inch or 1.5" wide. If it's into 100% of the width of the bushing, you're fine because the spline depth is more than adequate at that point.
Old May 19, 2014 | 08:48 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I will snap a pic tomorrow. Back when I did the ls tranny on a lt1 I was one of the first, so there was no information out there. It just looks like it's not in far enough for some reason.
Old May 19, 2014 | 09:19 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I Have an LS tranny and yoke is always in the boot seal, you can see any of the splines of the out put shaft. This is best picture I have.
Old Jun 6, 2014 | 04:16 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Is this ok? Keep in mind seal is not what's showing, that's just a dust seal. The actual seal is flush with housing. So it looks like I have about a couple inches of shaft inside tranny.
Old Jun 6, 2014 | 08:23 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
looks about rights to me
Old Jun 7, 2014 | 02:42 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
you should knock the rust off or it will kill that seal.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Nick McCardle
Sep 10, 2015 08:36 PM
tonys91rs
Sep 2, 2015 07:07 PM
