Thinking about an 8.8 ford rear swap?
Old Jun 24, 2014 | 03:36 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
A third gen rear is 62 inches wide axle flange to axle flange. A Ford 8.8 out of a 89 to 99 Ford Crown Vic is 62.5 inches from axle flange to axle flange, has 28 spline c clip axles and axle tubes the same diameter as,a,10 bolt.
So you can swap brackets and weld on a torque arm mount and use Ford wheels and be good to go.
Or you can cut off the ends of the tubes and weld on third gen 10 bolt tubes with brackets and use 90 to 92,28 spline thikrd gen 10 bolt axles....
Or you can use a 31 spline Explorer center with aftermarket 31 spline axles
OBX makes a really cheap $ 275.00, Helical gear LSD,that with a deburr and preload spacer kit, also cheap, fits the 8.8 and is bitchin strong. Per Rustang owners....
Just thought you should know....
Old Jun 24, 2014 | 07:08 AM
big gear head's Avatar
Re: Thinking about an 8.8 ford rear swap?
The torque arm mount is the hard part. You can't just weld it on. Welding steel to cast iron is not an easy job and should only be done by someone with a lot of cast iron welding experience. A bolt on bracket can be fabricated, but takes a lot of work. This isn't a job for the average person.
I didn't know that the Crown Vic had 2 5/8 inch axle tubes. I thought they were 3 inch.
Old Jun 25, 2014 | 05:59 PM
Granny's Avatar
Every crown vic housing i've had my hands on (several hundred), have had 3" tubes.
Old Jun 25, 2014 | 08:19 PM
That's what I thought. The 7.5 10 bolt has tubes that are about 2 5/8 inches.
customblackbird
Aug 15, 2021 10:16 PM
midge54
Jan 29, 2017 07:00 PM
IroczFan
Oct 6, 2015 10:13 AM
InfinityShade
Aug 22, 2015 08:00 PM
mizz0313
Aug 12, 2015 06:45 AM
