I have a leak and i think itrs the reare output seal?
Old Jun 26, 2014 | 08:07 AM
topj's Avatar
Car: 88 Camaro IROCZ Convertible
Engine: 305 tbi
Transmission: auto
So theres fluid on my garage floor and i already had an oil leak cause my oil pan is rusty but there was a second pool and i dabbed some paper towel and it was like reddish pink so thats gotta be the tranny , wasn't able to really get under my car but i was able to jack it up enough to slide my ipad under n take a look around with video and i have some pics . Do you guys think its the rear seal and how hard is it to change it yourself ? Thinking bout getting some ramps anyway so if i can do it myself ill check
Attached Thumbnails I have a leak and i think itrs the reare output seal?-image-580902890.jpg   I have a leak and i think itrs the reare output seal?-image-1098158999.jpg   I have a leak and i think itrs the reare output seal?-image-3385050319.jpg   I have a leak and i think itrs the reare output seal?-image-191960931.jpg   I have a leak and i think itrs the reare output seal?-image-3814363164.jpg
I have a leak and i think itrs the reare output seal?-image-4100920779.jpg   I have a leak and i think itrs the reare output seal?-image-4025776756.jpg
topj's Avatar
Engine: 305 tbi
Transmission: auto
Sorry for dark pics and title typo i jus woke up and cant stop worrying lol
Old Jun 27, 2014 | 01:03 PM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: I have a leak and i think itrs the reare output seal?
The most likely points for leaking fluid in a 700R4 is the rear seal, pan seal, and the dipstick tube seal. The front seal is also notorious for leaking but that would be seen on the flywheel cover. A rear seal can be replaced; the drive shaft has to be removed. If you're not comfortable with that or don't have the space(apartment parking), take it to a trans shop.
Old Jun 27, 2014 | 01:18 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Looks like your speedo cable is leaking. Needs a new bullet or O ring.
Old Jun 27, 2014 | 01:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
All those little leaks are part of the GM under body anti corrosion package.
Without them id have a pile of rust and not a car in the salt belt.
Old Jun 27, 2014 | 03:15 PM
topj's Avatar
Engine: 305 tbi
Transmission: auto
Really? Naw Im def leaking something though, but can the differential fluid leak up there ? sorry if thats a noob question lol but i did check the tranny fluid while idling and it was full mayb it may be something to do with the speedo cable or the o ring . Is it easy to replace by myself? I seen some other youtube videos on rwd cars and they jus bolt off , is it the same for us?
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
