Trans stuck in reverse
Old Jul 3, 2014 | 01:23 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Big problem.. Drove my 86 t/a with a 305 to work and now the car is stuck in reverse. It stalled when I got there because it shifted into reverse I assume. And now no matter where the shifter is at (automatic) it tools and is in reverse. I called a wrecker. What could be causing this? The shifter felt loose originally I just assumed due to age. Only 116k on the car.
Old Jul 3, 2014 | 01:33 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Trans stuck in reverse
shifter cable broken. reach underneath and manually shift it into drive to get it home.
(which would be two clicks back from reverse)
Old Jul 3, 2014 | 01:37 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Old Jul 3, 2014 | 02:55 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Originally Posted by Badass355ciz28
WITH THE ENGINE OFF!!!!!!!!!!!
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
First I really appreciate it guys!! I was really worried because when my Volvo transmission died it stuck in reverse so I thought this was another rerun.. The tow was quick for being at the airport and the guy was amazing. He got under the car and confirmed it was that linkage so he manually put it in drive while I held the brake and then drove it up the flat bed.
Shop had it done 30 minutes after the tow. Said the bolts had snapped so the put on new linkage and bolts. Tow and repair ended up being 125 at a professional ase shop. Only one in town I trust and cheap too!
This forum is a wealth of knowledge and I am really glad it exists!
camaro11j
Sep 19, 2018 08:49 AM
Rakim_RS25TH
Aug 27, 2015 05:04 PM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
