shift cable after swap
Old Jul 5, 2014 | 05:58 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
Yesterday 08:22 PM by budget builder
Re: another fitment quest.
dagblasted!!!! I didn't know that the shift cable for the v6 is shorter than for the v8. do they make an adapter?
Old Jul 5, 2014 | 12:47 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: shift cable after swap
Rock Auto shows the same shift cable for both V6 and V8.
Are you sure you talking about the manual shift cable and not the TV cable that attaches to the throttle?
Old Jul 5, 2014 | 06:00 PM
Car: 91RS
Shift cable. Park,rev,nuetral,drive. I'll keep trying
Old Jul 5, 2014 | 08:45 PM
Car: 91RS
Broken in console
Old Jul 7, 2014 | 08:23 PM
Car: 91RS
Brand new cable but still does not fully go into park. Missing it by 1/2in sommebody help me pleez
Old Jul 8, 2014 | 06:17 AM
Car: 91RS
post #34 street lethal helped us out thx!
https://www.thirdgen.org/forums/tran...djustment.html
I will try this when I go home from work
Old Aug 18, 2014 | 02:07 PM
Car: 91RS
got it in the console I had to use a pair of grip pliers and seat it into the bracket and then shift the tranny and the handle both into 1st then connect the tw0 and voila.
now, is there anyone who has measured there tv cable and know the distance between the mounting bracket and the throttle lever on an lo3 engine? that will give me a good starting point as to how far to mount the bracket from the throttle. thx am I even measuring right? or should I be going from carb to mounting plate(bracket plate) right now I can go to WOT in the 2nd pic and not pull out the slider I kno that is not correct so I kno that I have to move the bracket further back I just don't know how far. the small crook you see is just that only a little small crook it in no way interferes with operation. yu can see from where I measured tht the cable goes from 5in-6.25 in the 1st pic the cable has no slack but no pulling tension either and the slider is all the way in; in both pics.
in the 1st pic (idle) if I pull on or move the cable any further than where you see it I can feel while pulling it and hear something clicking at the tranny like a valve is opening. that's why I did not lengthen the cable any further for idle I did not know if that click was supposed to be happening at idle. if pulling by hand there is a 2nd detense that is clearly felt but the cable has to be pulled almost to where you see it in the second pic.
car: 91rs 3.1 to 357v8 both trannys 700r4
Attached Thumbnails shift cable after swap-img-20140817-00584-1   shift cable after swap-img-20140817-00585-1
Frozer!!!
Jan 19, 2024 04:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
timonator
Aug 13, 2015 11:27 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
