Where can I find a 3.42 rear end?
Old Jul 5, 2014 | 12:42 PM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
I have a 91 camaro rs. I want to switch the factory 3.08 to a posi 3.42. Should I just try to find a whole rear end? Or just buy the spline and carrier for it? My dad is gm master mechanic and is great with rear ends. But still, what should I do?
Old Jul 5, 2014 | 02:03 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Where can I find a 3.42 rear end?
My thirdgen came with 3.42 gears originally. I think most of the V6/T5 cars got that rear gearing. I swapped mine out for a 3.73 rear gear myself. First time I ever did a gear swap and I had no problems. Just the gears will be cheaper than a whole rear, but is more work. Or you could do what I did and put them in a fourthgen rear and get posi and disc brakes at the same time.
Old Jul 5, 2014 | 04:54 PM
Car: 1991 Camaro RS
So a 4th gen rear end will fit a 3rd gen?
Old Jul 5, 2014 | 07:18 PM
big gear head's Avatar
It will fit but it's about 4 inches wider. The tires will stick out a little.
Old Jul 5, 2014 | 07:24 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
where are you.i have a non posi one in my backyard.
Old Jul 5, 2014 | 08:57 PM
Car: 1991 Camaro RS
No I need a posi..
Old Jul 5, 2014 | 11:01 PM
It's a lot easier to install a limited slip differential (posi) than it is to set up a set of gears. You could install the LSD in the 3.42 rear end if everything else in the rear end is in good condition.
Old Jul 6, 2014 | 05:27 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Don't forget to change the speedo gear to keep your dash speed accurate.
Old Jul 8, 2014 | 04:51 PM
GBPhoenix88's Avatar
Car: '87 Trans Am
Engine: LG4
whats the diff with the gear ratio anyway, hows that work like the higher the ratio the more torque somethin like that?
Old Jul 8, 2014 | 08:36 PM
Car: 89 IROC
Higher the ratio, further the tire will travel per turn.
Old Jul 8, 2014 | 08:45 PM
Gear ratio has nothing to do with how far the tire travels per revolution. Gear ratio has to do with engine RPMs at certain speeds (transmission and tire diameter also must be considered) and leverage, or torque multiplication.
Old Jul 8, 2014 | 09:04 PM
Car: 89 IROC
if you say so....
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
