Keep tearing up speedo gears
Recently swapped out my 84 700r4 trans in my camaro for a newer one out of a caprice changed out the tail shaft so I could use my cable speedo but now I can tearing up speedo gears any ideas why?
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Keep tearing up speedo gears
Did you also swap the speedometer drive gear from your original transmission into the transmission out of the Caprice?
Car: check
Engine: check
Transmission: check
Speedo gear is in the wrong location. There are two holes in the shaft for the drive gear retaining clip, use the other one.
RBob.
RBob.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
For everything EXCEPT for a Vette,... It's the hole closest to the CASE. ( all the way UP the shaft )
Could also be the wrong VSS, wrong gear, or combination of the 2. VSS ( cable AND electric ) are made for only a range of driven speedo gears. ( not ALL tooth counts will fit.) This range of tooth counts is usually found somewhere on the VSS itself.
Cable and Electric Driven gears are not the same. If you use an electric speedo gear on a cable VSS than expect problems. Be sure that you are using a Driven gear made for a cable application and that the Driven gear is within the range of acceptable tooth counts for the VSS.
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Yep, I had this happen to me once. It will still work with the gear in the wrong location but the mesh is very slight. Mine lasted a couple hundred miles before it wore enough to no longer work.
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I had a 700r4 driven gear crack while cruising. That let it work itself out of position. Suddenly my speedometer stopped working.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
