will an 88 z28 3.42 posi rear bolt up in my 86 trans am
Old Sep 25, 2014 | 09:15 PM
Ebayparts's Avatar
Car: 86 t/a
Engine: lg4 305 carbed
Transmission: 700r4 auto
Axle/Gears: stock 2.73
I have an 86 trans am with a 2.73 rear. I also have a parts car 88 z28 will its rear just bolt up in place?
Old Sep 26, 2014 | 06:54 AM
big gear head's Avatar
Re: will an 88 z28 3.42 posi rear bolt up in my 86 trans am
Yes, as long as they both have the same brakes.
Old Sep 26, 2014 | 07:53 AM
Ebayparts's Avatar
Car: 86 t/a
Great thanks. I have upgraded rotors and calipers on 2.73 rear. Shouldnt be a problem to switch them over.
Old Sep 28, 2014 | 07:31 PM
Night rider327's Avatar
Car: 1988 Camaro
Yep a direct bolt in swap, but you might not be gaining much. Most of the '88 Irocs came with the same 2.73 gear if auto car, 3.08 if man. trans car
With a G92 option then a 3.23
Old Sep 28, 2014 | 07:49 PM
Ebayparts's Avatar
Car: 86 t/a
Good to know. He upgraded stuff in car if you do the spin the wheel and count the driveshaft spins a 3.45 rear. Yes 3.45 not 3.42 i misprinted it in op. Thanks for the responses and help
Old Sep 28, 2014 | 08:13 PM
Ebayparts's Avatar
Car: 86 t/a
Ok so its a 3.42 rear. Im not a gears person. clearly. But hey its why you guys are here right.
Old Sep 29, 2014 | 12:48 AM
Car: 1988 Camaro
The 3.45 gear was G92 performance axle option for the '88 but it will be the 9 bolt borg warner rear end, not the 10 bolt.
No factory option for a 3.42 gear in a V8 1988 F body, but it's not that big of thing to re gear or have rear end re geared, or to even swap whole rear end out so maybe that's what was done.
Old Sep 29, 2014 | 06:21 AM
Ebayparts's Avatar
Car: 86 t/a
Ok. So he did have the rear re geared. Its the 3.42. His car drove great ,pulled hard. His is 350 not my lil lg4. Thanks for your help Knight rider327
LilHot
South Central
Apr 13, 2026 11:46 PM
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
