Drive by wire electric kickdown th400
Old Oct 11, 2014 | 09:33 PM
madbomber824's Avatar
Car: 1986 Camaro
Engine: 350-Carb
Transmission: 700-R4
Setting up ls/vortec motor with drive by wire. Is there anyone with a picture of it setup with a momentary switch on the gas pedal? What part number switch works best for it? At what position throttle should it engage? WOT?
Thanks,
Old Oct 25, 2014 | 10:14 AM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: Drive by wire electric kickdown th400
not sure if you could rig up a pedal switch like any of the older cars/trucks that used TH400, but find one of those and look just above the gas pedal, that's where they are. The switch should actuate wherever you want the trans to kick down to passing gear -- if I remember correctly it's anywhere from 3/4 to 7/8 throttle travel....
if you are having someone make the harness/program the computer, I would think they should be able to add an output for the passing gear solenoid.....
Infested
May 22, 2018 11:56 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
lakeffect2
Aug 23, 2015 08:44 AM
