TH700R4 PROBS - NO DRIVE AT ALL
Old Oct 27, 2014 | 08:10 AM
ts210's Avatar
Car: 1983 Chevy Camaor Z28
Transmission: Power Glide
Just bought a 1985 TA WS6 starts and sounds great but won't go anywhere.
Checked fluid, looks like new and levels fine.
Jacked up rear and selected 1st gear, wheels started turning for a minute or so at idle. BUilt up the revs, wheels turned quicker but then started to slow and eventually stopped.
No history of whats wrong with the Trannie but was told it has been off the road for 10 years but driven recently??
I've also been told by a guy who knew the previous previous owner that the box will prob need a rebuild.
Any advice and what to check first would be great.
I'm been told to check the transmission selector on the box, check hydraulic pressure and trannie tail and diff for movement.
Old Oct 28, 2014 | 06:15 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: TH700R4 PROBS - NO DRIVE AT ALL
was fluid level checked with engine running?
Old Oct 29, 2014 | 02:34 AM
ts210's Avatar
No, does that make a difference?
Old Oct 29, 2014 | 01:21 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
makes a big difference-fluid level is supposed to checked with engine running,will show "high"on the stick if checked engine off.symptom you give can occur with low fluid level-if tranny sits unused for a while,fluid can drain out of torque converter,raise fluid level in pan beyond normal-causing fluid to flood out of speedo gear fitting or dipstick grommet if those seals are old and leakey.Pour some more fluid in and see if tranny starts to work
Old Oct 29, 2014 | 02:46 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
^^^^^ What He Said ^^^^
Cleotiz
Jan 6, 2018 08:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
