Ford 9" Axles
Old Nov 13, 2014 | 08:56 PM
cycleguy04's Avatar
Car: 1983 Z28
Engine: life is more nifty with a chevy 350
Transmission: TH400
Axle/Gears: 10 bolt, unknown gears
Ford 9" Axles
I got a '78 Bronco rear end that is 65" flange to flange. There is about 2-3" of the axles sticking out of the housing. If I were to convert to disc brakes could I get axles that sit further into the housing effectively narrowing the rear end?
Old Nov 14, 2014 | 06:57 AM
big gear head's Avatar
Re: Ford 9" Axles
No, axles hang out a certain amount to allow for the brakes. GM used 2 3/4 inches and most of the 9 inch Fords used 2 1/2 inches. The brakes are made to work with this amount of hang out. The axle bearings and the radius on the back of the axle flange also need room. You can not alter the amount of hang out on the axles to change the rear end width.
Old Nov 14, 2014 | 08:11 AM
cycleguy04's Avatar
Car: 1983 Z28
Transmission: TH400
Re: Ford 9" Axles
Thanks.
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
rudolphschenker
Sep 4, 2015 02:41 AM
