Posi Rear End
Old Feb 25, 2015 | 08:41 AM
jesse300mph's Avatar
Car: 1987 Camaro
Engine: 2.8L V6
Transmission: 4 speed auto
Posi Rear End
I have an 87 Camaro v6 automatic tranny im looking to get rid of my LSD and I found a 10 bolt posi from a firebird I believe its a 2.73 gear. Does anybody know how hard of a swap this would be im not familiar with it and would it still work when I eventually swap it from a 2.8 to a 305 or 350 whichever would be easier?
Old Feb 25, 2015 | 03:15 PM
Re: Posi Rear End
If you have a limited slip differential, you already have "posi". "Positraction", commonly abbreviated "posi", was simpy GM's trademark for the Eaton limited slip back in the 60s, and even after that unit was discontinued, the name stuck.
However, if your car came with a 6-cyl, it probably doesn't have it. More likely, it currently has an "open", or "unlimited slip" if you will, unit.
Swapping a rear is easy.
You will HATE HATE HATE HATE a 2.73 gear. Getting a stock Auburn POS "posi", which is amost certainly wore out and non-functional and non-repairable is not worth putting up with .... that.
Old Feb 25, 2015 | 10:47 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Posi Rear End
Posi (Positraction), limited slip, sure grip, twin traction, twin-grip, trak-lok, powr-lok, Safe-T-Track are all the same things. Just diff. words/terms for the same action/part.
A non LSD rear would be an OPEN differential.
Your '87 v6 car should have a 3.42 gear 10 bolt open rear end under it now.
I would take the open rear with better gear over the posi/limited slip with a 2.73 any day of the week.
To answer your question though. A rear end swap is not hard at all. Only 7 bolts to remove, plus 4 bolts on driveshaft, then brake line and E-brake cable, and of course the wheels.
Old Feb 25, 2015 | 11:24 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Posi Rear End
Note that if you are just swapping the diff and not the whole rear end then it requires you to properly shim the pinion gear and differential so that they have proper preload and mesh pattern, which is a bit trickier than just wacking on a whole rear end assembly. If not done right you'll end up with gear whine very soon after putting it back together.
Old Feb 26, 2015 | 06:37 AM
Car: 1987 Camaro
Engine: 2.8L V6
Re: Posi Rear End
So what would the difference between an LSD and open would just be that one wheel spins? what does the gear ratio do exactly Sry I'm used to all my front wheel drive cars haha
Old Feb 26, 2015 | 07:31 AM
Car: 1988 Camaro
Re: Posi Rear End
Yes, an open rear end will send power to 1 wheel.. Posi/LSD/limited slip sends power to both wheels.
The higher number (lower gear) gives you better acceleration, and turns more rpm per mph. The best way to put how it feels into simple terms would be to say a 2.73 rear gear vs a 3.42 would kinda feel like driving a manual transmission car and starting off in second gear rather than 1st gear
Old Feb 26, 2015 | 07:47 AM
Car: 1987 Camaro
Engine: 2.8L V6
Re: Posi Rear End
Ok thank you that explains a lot.
Old Feb 26, 2015 | 02:28 PM
someone972's Avatar
Engine: 5.7L TPI
Re: Posi Rear End
If you want to learn more in-depth of how LSD's work, youtube is actually a great resource since you can actually see what's happening as they are explaining it. Just search 'Limited Slip Differential' and there will be a bunch of great videos explaining what the difference between the LSD and open diff are.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
neekolzun
Aug 24, 2015 04:59 PM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
