700r4 Swap
Car: 90 Camaro Iroc-z
700r4 Swap
Can I take a 700r4 out of a 90 Camaro Iroc with a 350 and bolt it directly up to a 78 Camaro with a 350? Will I have to change any other parts besides the speed sensor and driveshaft?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 700r4 Swap
It will need a way to control the converter lockup.
Car: 84 Z28
Engine: 383 Stroker
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 700r4 Swap
TCI sells a nice converter lock up kit for around $70.00. You will also need a different length drive shaft and I believe transmission cross member as the bolt locations will be different.
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: 700r4 Swap
Does the 78 use a vacuum modulator? If so you'll have to find a way to mount the TV cable.
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
