best driveshaft for budget
Old Mar 30, 2015 | 10:26 PM
gmoutdoorsman's Avatar
LS/4L60e swap and want to know what route I should take when deciding on a driveshaft.Wanting something that will support up to 600 rwhp and not break the bank. What are my options
Old Mar 30, 2015 | 10:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: best driveshaft for budget
Custom made steel shaft with 1350 yokes. Also means you'll need a 1350 trans and diff yoke.
My steel shaft is 3" x 0.083" custom made and balanced by a local driveline shop.
Old Mar 30, 2015 | 10:42 PM
How much did it cost total? I was looking into aluminium 4th gen shaft but ive heard they're weak after 400hp. Hmmm my uncle runs a driveshaft shop, how ironic lol
Old Mar 31, 2015 | 06:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It was a long time ago but I think the shaft was around $300-$400 to have it custom made. Depends on the availability of all the yokes required. Trans, diff and both yokes for the driveshaft.
Aluminum driveshafts are nice but OEM shafts are not very strong. An aftermarket aluminum shaft may be around $700 but even then, I wouldn't put one behind my engine. A properly balanced steel shaft is stronger than an aluminum one. The weight saving is minimal.
cheesehomer
Dec 31, 2015 08:48 AM
loud91rs
Oct 5, 2015 10:05 PM
drumstixer
Sep 29, 2015 03:02 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
