4th gen master, 3rdgen pedals bushing
Old Apr 30, 2015 | 01:25 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
What are my options? The 4th one doesn't fit and I destroyed it trying to make it fit...
Old Apr 30, 2015 | 09:52 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 4th gen master, 3rdgen pedals bushing
Did your 84 have a T5 to start?
Getting the master cylinder in place so the u-bolt lines up and goes into the firewall takes practice and patience.
Sometimes having a helper to direct which way the parts need to move (or move the parts while you view from the interior) in order for it to fit is a good thing.
Old May 4, 2015 | 03:31 PM
Engine: 357
U bolts? I just bolted it in works fine for me. I dont know what todo about the bushing though... 4th gen one is too small for the stud on 3rd gen pedals
Old May 4, 2015 | 05:18 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Go to your local ace hardware. You need a delrin or plastic bushing with an outer diameter that matches the ID of the 4th gen master.
Then you need to drill the bushing out so it matches the diameter of the peg.
Once you've done that you need to put a washer on the peg with a diameter larger than the master to hold it I place and lock it with the clip.
Old May 6, 2015 | 04:17 PM
Engine: 357
Anyone have a 4th gen master laying around to get me a measurement? Mines all installed
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
