v8 transmission for v6 ?
Old May 21, 2015 | 10:59 AM
mikiman's Avatar
Hello everybody,
I broke my 3.1 v6 1990 firebird transmission, and in Europe it's very dificult find spares. In USA it's easy, but the delivery it's so expensive as the gearbox, and I have found one in my country. But it's a V8 1987 5.0 Trans AM transmission. Do you know if can I adapt it ? the bolts position are diferent, and I supose that must be any kit to put it, with spacers and plat adapter. Is it ? what more I need? It will runs ok? were can I buy it ? Must I modifi something, the V8 it's bigger and the torque converter it's diferent too.
Thanks a lot and sorry for my bad English
Old May 21, 2015 | 02:09 PM
Re: v8 transmission for v6 ?
Bolt pattern is identical. Might look different, but it's not.
The difference in that particular feature is the year model, not the engine type.
Your trans should look like the bottom one; the 87 will look like the top one. Be assured however, the bolts are in the same place.
All you will have to change is the clutch disc (use a V8 one); and of course you might need a speedometer gear to get that to read right.
Old May 21, 2015 | 03:20 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I think he has an automatic but I might be wrong. Maybe he confused torque converter with clutch
Old May 21, 2015 | 03:50 PM
You're right: sorry, I should have read more closely.
No, a V8 automatic will not fit a 6-cyl engine. In the manual trans like the above, the trans bolts to the bell housing. The auto however bolts directly to the engine and its bolt pattern is different.
You have no choice other than a 6-cyl transmission.
Old May 22, 2015 | 09:14 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
No, this will let you bolt the V8-spec 700R-4 to a 2.8 / 3.1
http://www.speedwaymotors.com/60-Deg...late,3280.html
Old May 24, 2015 | 07:09 AM
cosmick's Avatar
Good going, Sofa, scare the new guy away with wrong info, then not even admit you stand corrected. Couldn't you at least have suggested putting the V8 guts in the V6 case with a rebuild kit? I've done my own 700R-4 with a B&M kit, their instructions were good enough. It went from first and reverse to all 4 gears plus reverse. Since I did, he could.
Old May 24, 2015 | 08:39 AM
Scuze me?
Old Oct 7, 2016 | 06:47 AM
mikiman's Avatar
Hello. Sorry for the delay in my answer.
Yes, I have an automatic transmission.
I found a kit to put a v8 into my v6 motor, but not for the third gen. It'sw consists in 1 inch thick aluminium adapter plate, torque converter drive-plate, bolt set, and cranck adapter:
http://www.transmissionadapters.com/...0%20series.htm
I really need all this pieces ? I have both torque converter, for the v6 and for the v8.
It's a heavy kit, and the delivery it's so expensive as the kit
thanks a lot
Old Oct 8, 2016 | 12:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
thanks a lot
No that's not for the correct trans, that's a 3800series.
The one cosmic posted is what u meed
Old Nov 3, 2016 | 07:45 AM
mikiman's Avatar
Hello. I have told with speedwaymotors, and this adapter will not go OK.
If must I built an adapter, have somebody the exactly sizes of the transmision and the holes size and position?
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
