Need drum break axle shaft advice
Old Jul 28, 2015 | 05:25 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Have a bad axle shaft. The rear came out of a 91, and it's a drum. I've seen some different stories about if a New axle will go right into a car with a drum rear end, or if a axle from a disc car will work in a drum rear end. Can anybody clear that up for me? I don't mind buying new, but there's a post on TGO that make me wonder. Here it is:
Are Drum/Disc Axles Interchangeable?
Yes, but the drum axle flange will have to be turned down to fit the rotor.* The flange diameter on the drum shaft is 6.0"; the disc shaft is 5.850" and the ID of the brake rotor is 5.900". (Oddly, there is no distinction made between drum and disc when ordering after market axles.)
SO i need to know if I can take a shaft out of a disc rear and put in in my car, or I can order new ones if they are compatible with a drum rear end.
Old Jul 28, 2015 | 05:39 PM
Re: Need drum break axle shaft advice
Yes an axle from a disc will fit inside drums.
The problem is going the other way: the drum axles in earlier rears won't fit inside those old teeny tiny rotors.
Old Jul 28, 2015 | 05:41 PM
58mark's Avatar
OK, thanks
dbrochard
Oct 3, 2015 12:43 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
