Need help identifying 10bolt rear end
Old Sep 8, 2015 | 03:33 AM
Numbah-1's Avatar
Car: 1984
Axle/Gears: 10 bolt
Hi guys, first post! I could use some help. I have a 84, but there is so much 4th gen things on my car I'm a little confused on what I have. It's an open non posi 10 bolt with disc brakes. It's 10.5 tall and 9.5 wide from the one end of the cover to the other. It looks totally different than the rear end on my 92 RS, but I think it's just traction bars thats throwing me off. I was going to check the fluid in it today but instead of a plug there was a plastic cap covering what felt like a giant grease insert.
1. How do I check the fluid or even fill it?
2. Do you guys think it's a standard 7.5? With the T56 the gears are way apart like it could be 3.23 or even 3.08! Way different than the 3.42 and T5 I'm use to.
Old Sep 8, 2015 | 06:42 AM
Re: Need help identifying 10bolt rear end
http://www.ringpinion.com/b2c/DiffLi...=Diff&TypeID=5
Don't guess at the gears. Change the fluid instead; and count the teeth while you've got the cover off draining it.
Old Sep 8, 2015 | 07:00 AM
Twin_Turbo's Avatar
ring gear is stamped with ring nd pinoun amount of teeth, no need to count
Old Sep 8, 2015 | 07:07 AM
big gear head's Avatar
Is it a 10 bolt or is it the 9 bolt Borg-Warner rear end?
Old Sep 8, 2015 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the 10-Bolt FAQ sticky at the top of the page.
JamesC
Old Sep 8, 2015 | 06:27 PM
Numbah-1's Avatar
Car: 1984
Axle/Gears: 10 bolt
Im not worried about the gears yet, but I also dont want to take the cover off if I cant add more fluid.
Further more, I checked the sticky 3 or 4 times now, I'll measure the axles in the next few days. It is a 10 bolt, thats why I dont understand why there's a grease insert. Those only came on the 9 bolts! Its so hard to see too lol
Just to add it might not be a 3rd gen part because my car has; LT1, T56, 4th gen column and somehow different dash... which I could only imagine would be 4th gen hahah
Old Sep 8, 2015 | 06:35 PM
JamesC's Avatar
You can, of course, add fluid.
There isn't.
These issues are all addressed in the sticky. Please reread.
Best of luck,
JamesC
Old Sep 8, 2015 | 09:26 PM
Can you post a picture of the cover? I'd like to see this insert.
Old Sep 9, 2015 | 12:20 AM
Twin_Turbo's Avatar
Sounds like a 9 bolt
Old Sep 9, 2015 | 01:38 AM
Numbah-1's Avatar
Car: 1984
Axle/Gears: 10 bolt
I should have labeled the thread different. What ever plug is, its really hatd to get to. Is kinda why I was asking how I could add diff fluid. Since its not a 1/2-14x39/64. GM 25522466.... And the only other plug Ive read about was something along a grease insert, I thought it was that. I know I can, ...in fact.. add fluid lol I just dont wanna mess it up. But I'll take my wishes of luck and be on my way.
Old Sep 9, 2015 | 02:23 AM
Night rider327's Avatar
Car: 1988 Camaro
Can you post a picture of it? The whole rear, the cover, the plug?
A picture is worth a thousand words, you know.
Have you cleaned the axle tube and got the numbers/codes off it? It will be on the pass. side axle tube, on the side towards transmission.. It will be a code with a letter, 2 numbers, a space and 4 numbers and a letter.
The Letter & 2 numbers are the gear ratio code, The next 4 numbers are month and day, then the Letter is the plant code.
Old Sep 9, 2015 | 02:28 AM
Car: 1988 Camaro
Just thought of this... Maybe you have the 'rare' Dana 44 rear. IIRC some of those had the plastic plug looking thing in the cover, and they have 10 cover bolts as well.
Old Sep 9, 2015 | 03:05 AM
Twin_Turbo's Avatar
Yes, it has a square drive plug:
Dana44:
dana.jpg?t=1304654858
Old Sep 9, 2015 | 08:16 AM
I'm thinking he's thinking, the plastic vent tube on top is the fluid fill.
Which of course, its not... the fill in a 10-bolt is on the pass side at the front of the round part of the pumpkin before it narrows down to the "snout" for the pinion, about halfway up.
So, original poster, when you went to the page I linked you to and compared your cover shape to all those, did it match any of em? That casting number you posted (that's what it is... just, the casting number of the big chunk of cast-iron in the middle of the housing) sure does sound like yerbasic 7.5" 10-bolt.
Old Sep 12, 2015 | 05:44 PM
Numbah-1's Avatar
Car: 1984
Axle/Gears: 10 bolt
My apologies James, you were right. It is a vent tube. It cant be a grease insert. I tried to get a picture but it never comes out. The vent tube is on the passenger side though. I havent felt a plug that mates to an rachet though. Should I be looking on the other side of the diff for the plug? If I can find the plug to add more, I could pull the cover off and maybe use my dial calipers to measure it.
Old Sep 12, 2015 | 06:01 PM
Pretty eeeezy to spot.
Old Sep 12, 2015 | 06:04 PM
The plug is on the right side of the center casting in front of the axle tube. Use a screwdriver to dig the dirt off of it.
Old Sep 12, 2015 | 06:21 PM
Numbah-1's Avatar
Car: 1984
Axle/Gears: 10 bolt
Can I delete this? I just found that plug. Its under the passenger side axle.
Old Sep 12, 2015 | 06:28 PM
Nah; won't hurt anything; just add more fluid now that you know where.
Old Sep 12, 2015 | 08:57 PM
Car: 1988 Camaro
Yep, just a std. 7.5"/7.625" 10 bolt. The fill plug is on the pass side. On the chunk close to where axle tube goes in at.
No drain on these, to drain you remove cover.
Stick your pinky in the fill hole and bend it down, if you can touch gear oil it's full. If you can't touch the oil it needs more.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
