3.08 to 3.23
Old Oct 31, 2015 | 02:02 AM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
3.08 to 3.23
Got a 1982 Z/28 it has the stock diff in it but I had a 3.08 possi fitted a year back..
I want to go down to a 3.23;1 diff as I am changing tire height.
Will my Diff Carrier allow me to go to the 3.23;1
I think its a 26 spline 7.5 inch thing if I remember #^~*
Old Oct 31, 2015 | 07:17 AM
Re: 3.08 to 3.23
That's the exact point of the break between 2 and 3 series carriers.
Stock 3.23 gears will not work. You'd have to use the "special" thick ones.
That's ALOT of maze to run in return for VERY LITTLE cheeeze... that difference in gearing is only barely perceptible. For the amount of money and work it will take, might want to consider a bit more of an improvement than that.
Old Oct 31, 2015 | 08:25 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: 3.08 to 3.23
I'd try the new tires with the old gears, and recalibrate the speedometer, before considering such a gear swap. It'll be very difficult to notice much difference.
Old Oct 31, 2015 | 09:50 AM
big gear head's Avatar
Re: 3.08 to 3.23
I agree that this is such a small change that it wouldn't be worth the trouble. You can get the special thick gears that will work with the 2 series differential that you have. If you have an Auburn or a Governor Lock then I would consider replacing it with something better at the same time as the gear change. The Auburn and Governor Lock are junk, and by changing it you can also go to a 3 series differential. I would at least go to a 3.42 and use a Eaton Posi, Yukon Dura Grip, Power Trax Grip LS or a Eaton Truetrac.
Old Oct 31, 2015 | 11:12 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: 3.08 to 3.23
What size diameter tire are you going to run ?
Also, what's with the large blue lettering ?
Jaysome
Oct 31, 2015 07:47 PM
1nastyRS
Oct 28, 2015 11:04 AM
Robert14t
Wheels and Tires
Oct 22, 2015 02:34 AM
Dkelz313
Wheels and Tires
18
Oct 21, 2015 08:19 AM
19irocz85
Wheels and Tires
Oct 16, 2015 07:31 PM
