Shifter hits console?
Old Feb 7, 2016 | 06:49 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
In my '89 firebird which the previous owner out a thirdgen Camaro center console on I've got a t5 with pro 5.0 shifter- the shifter hits the forward part of the console. I've tried flipping the shifter and with the letters backwards to the driver is the only way it goes in all the gears. I know the t5s lean towards the driver. Is this an issue with the Camaro console or? Tranny and engine are bolted down so I don't see what else could be the issue.
Old Feb 7, 2016 | 06:52 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Re: Shifter hits console?
Mods please delete-double post
Old Feb 7, 2016 | 08:17 PM
Given all the other details in your post, wouldn't be surprised if it's not a thirdgen shifter.
Old Feb 7, 2016 | 08:33 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
It has "Camaro/firebird 83-92" scribed into the metal.
Old Feb 8, 2016 | 03:02 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I put the stock shifter in place and it's also hitting the console in 1st gear. Could not have the tq arm top bolt and driveshaft connected be the cause?
Stock shifter in neutral
Old Feb 8, 2016 | 04:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Maybe a dumb question but is the console bolted down in the proper spot? Looks a tad to far back judging by what I'm seeing
Old Feb 8, 2016 | 08:38 PM
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
I'm kinda not the smartest on this topic, but, I have a 4th gen motor and trans, and it doesn't hit anything.
just looking at your top pic (which is kinda dark) it almost looks like the center console isn't mounted all the way forward.
Also, you said it was a Camaro console with a Firebird dash?
That might be where the issue lies. I haven't been inside a 3rd gen firebird in many years, but I imagine it isn't a total fit.
You could just do what I did for a while and Mad Max it, no console, no carpet, no worries.
Old Feb 8, 2016 | 09:01 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Yes previous owner swapped a thirdgen Camaro console in which is cracked in a few places. I honestly didn't think of that as it wasn't bolted down in the pics so I'll have to mess with it tomorrow.
Old Feb 8, 2016 | 09:09 PM
Oh... it's a stock shifter... about like the one I threw in the trash in the early 80s when I busted my knuckle on the radio shifting into 3rd... no wonder everything hits everything.
Throw that in the trash and get an aftermarket shifter.
Old Feb 8, 2016 | 09:12 PM
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
Man, too bad you aren't around here. Myself, I've had the console apart at least 4 times, now I am good at it. Plus, there are 2 u pull junkyards that have had a few firebirds. Looking around on google, it's hard to tell, but the Camaro and Firebird do look the same. If I remember right, there are two big screws on the console in the compartment, and two under that in the actual "frame" of the console. If those bottom two that mount the "frame" part aren't in, or skipped, the whole thing will sit wherever it feels like it.
I would get some pics of mine, but I am REALLY tired of taking that thing apart over and over. maybe someone can describe/clarify better?
Good luck!
Old Feb 8, 2016 | 09:17 PM
Old Feb 8, 2016 | 09:38 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
I have a pro 5.0. I just put the stock shifter on to see if the shifter itself was the issue.
Goodolboy0404
Apr 28, 2016 10:09 PM
LsxMatt
Feb 13, 2016 10:44 PM
Night rider327
Feb 11, 2016 11:41 PM
Camarokid00
Feb 5, 2016 11:18 AM
cosmick
Feb 4, 2016 11:31 PM
