View Poll Results: How many has had this problem?
No bolts
0%
Cracked flex plate
50.00%
Fixing someone else's works
50.00%
Voters: 2. You may not vote on this poll
Re vibration found
Old Mar 4, 2016 | 06:24 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Re vibration found
Started the flex plate removal and found yet more things wrong. I found that the previse owner did not put but half bell housing bolt's . 3 is all I found and only at the mid part of trans. Flex plate is cracked all the way around going back togother tomorrow and see what happens.
Old Mar 4, 2016 | 07:24 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Re vibration found
Pretty serious lack of maintance issue , probably someone discount place the owner went to that did that.
Old Mar 4, 2016 | 08:12 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
is that an external balance flexplate? i noticed the welded on weight.
Old Mar 5, 2016 | 10:31 AM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Its the same as I took out
Old Mar 5, 2016 | 11:57 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
That is normal for the 1-piece RMS crank. The external counter weight on a 2-piece RMS crank gets "moved" off the crank, to allow the seal to fit over, with the weight moved to the flexplate/flywheel to maintain "internal" balance.
Old Mar 5, 2016 | 04:31 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
All done and there is no vibration or sounds at all. Car is like new and all is great!
Old Mar 5, 2016 | 06:13 PM
Flex plates crack like that all the time; very common actually. Their usual and accustomed failure mode.
Worse, I know of more than one car whose owner refused to believe that that's what was making all the racket, and scrapped the car. What a shame. (well, maybe not... happened to K-cars ALOT)
Glad you found the problem and didn't waste a bunch of time money and effort on "replace engine".
astout82
Exterior Parts for Sale
Mar 30, 2016 03:03 PM
Ajdd94
Mar 10, 2016 04:23 PM
92tealZconv
Mar 8, 2016 06:12 PM
3rdgentofourth
Mar 4, 2016 09:15 AM
Tas
Mar 3, 2016 09:10 PM
