Need info
Old Mar 5, 2016 | 05:06 PM
Dodge300's Avatar
Need info
I found a 85 I roc with a 350 and was told a 700r4 auto Trans the guy said that he overfilled the transmission and it shifts when it pleases. a friendgave me a heads up about this and was told that it's either lock up in the converter or valve body can some one help me before I trade off my truck for it
Old Mar 5, 2016 | 05:37 PM
nhgator's Avatar
Car: 1985 T/A
Re: Need info
I would tell the guy to drain some fluid,set it to the correct level and then we'll talk after we see if it gets it's memory back.
Or,plan on a rebuild.
Old Mar 5, 2016 | 06:19 PM
Re: Need info
http://www.homedepot.com/p/Everbilt-...3-HD/204667248
No need to listen to a bunch of used-car-seller mealy-mouth weasel-words. Cut to the chase, see if it really works or not. Drain it yourself if you have to. Adjust the price accordingly.
Being a 700R4, it has no "memory". Purely mechanical/hydraulic. Either it works or it doesn't, pure and simple. It "remembers" absolutely nothing whatsoever at all ever for even the slightest length of time. Either it works with the right amount of fluid, or it doesn't.
Q: How can you tell a used-car seller is lying?
A: His lips are moving.
Q: How can you tell a used-car seller is stabbing you in the back?
A: He's smiling.
Eliminate the bullshit and jump directly to the truth, don't let the stars in your eyes get in the way.
Old Mar 5, 2016 | 06:53 PM
nhgator's Avatar
Car: 1985 T/A
Re: Need info
Damn,Sofa,you should write cards for Hallmark,they could open up a whole new aisle..............
Old Mar 5, 2016 | 07:36 PM
Dodge300's Avatar
Re: Need info
Ok now he's telling me is a th350 and needs a detent cable
Old Mar 5, 2016 | 07:39 PM
nhgator's Avatar
Car: 1985 T/A
Re: Need info
Run,Forrest,Run
Old Mar 5, 2016 | 07:41 PM
Dodge300's Avatar
Re: Need info
Think I'm going to I wanted the car but I'm not trading my truck which I just replaced the Trans in for another car that needs a Trans
Old Mar 6, 2016 | 09:56 AM
Re: Need info
How much ya wanna bet that this alleged "350" magically turns back into a 305 the minute some money changes hands?
Good idea to just walk away from that one.
I should correct myself: the 700-R4 trans DOES have a limited memory, of ONE thing: being ruined. Burned up, tore up, etc. It remembers that. Doesn't forget it so easily, unfortunately.
Old Mar 6, 2016 | 12:37 PM
Dodge300's Avatar
Re: Need info
Yeah no money switching hands a straight trade for a 79 dodge 300 with a new Trans nope I'm not doing it done it once to get the 79 and I had to buy a new Trans so yeah I walked away really fast. Thank you alol for the help
Old Mar 6, 2016 | 01:03 PM
Re: Need info
A trade is kinda the same thing as money; once the seller has the thing of value and you have the thing that maybe has less than you were led to believe in the beginning...
But yeah, glad to hear you decided to walk. I REALLY hate seeing people get screwed, which this had all the earmarks of. Too bad the bait was one of these cars.
Ohlmin
Jul 13, 2016 09:30 PM
pfsteichen
Convertibles
Mar 24, 2016 09:05 AM
LB9GTA
Mar 6, 2016 09:46 PM
Phirewire
Feb 15, 2016 10:08 AM
cattiveria665
Camaros Wanted
Feb 8, 2016 09:09 PM
