S10 torque converter
Old Apr 14, 2016 | 01:10 PM
mrestrictrplate's Avatar
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
I keep hearing about guys that have Chevy S10 torque converters in their 700r4s. In one of my 87 Irocs I put a B&m 2400 converter in and it feels same as stock. I hear the S10s are 2400 to 2600 reall stall rpm and are good for a little extra launch .. any input or experience? Thanks Chris
Old Apr 14, 2016 | 01:22 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: S10 torque converter
Mine has one. Don't know how much better than stock its been so long since ive drove a stock one. Id say mines really more like 2200 stall it launches pretty good with that and the 373s. Shes all done by 100ft though..Lol
Old Apr 14, 2016 | 06:02 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
If you have a lot of rear gear, like a 3.73:1, then a loose converter, like a 2500+, is going to drive near-stock. Swap to tall gears like 2.73:1, and the difference in torque converters becomes dramatic. Then the loose converters become annoying.
The L35 S-10 converter is the loosest stock GM V8-compatible converter, is NOT as loose as a B&M TorkMaster 2400, and is a cheap alternative to the B&M.
The 2.2L S-10 converter is much looser than 2.8 / 3.1 converters
Old Apr 14, 2016 | 06:26 PM
This car has the stock 2.73 in it. It's a dog
Old Apr 14, 2016 | 06:31 PM
Thanks for the info. This is my mostly stock 87 I have one im building with heads superram and 3000 stall 10 inch in it. I'm just bummed I put this b&m in this car and it drives like it did stock.
Old Apr 14, 2016 | 06:51 PM
The S truck converter is a lot like the Vega converter was back in the day.
Yeah, it stalls higher. Yeah, it scores higher on the butt dyno than a V8 one, in some ways sometimes.
BUTT:
Go to the track. Are ANY of the cars THAT WIN running one???
And there's your answer.
On to the next topic:
b&m
There's your other answer, to the question you didn't quite ask yet.
The 3rd answer is
You already answered that unasked question yourself.
Old Apr 15, 2016 | 08:08 AM
cosmick's Avatar
What's winning at the dragstrip doesn't matter for making a daily driver fun, most of those drag winners would be hell for commuting.
I had a '95 Z28 convertible with the 2.73:1 axle, couldn't break the rear tires loose with the stock 1500-stall. Swapped the B&M TM2400, instant traction problem, very fun for making twin black stripes on the pavement, but aggravating and frustrating for normal driving.
Next I had a '91 RS LO3 with the 2.73:1 gears. Stock 1500-stall in that one, too. I eventually pulled the TBI, gave it the '87 Monte L69 intake manifold, an '80 LG4 Q-Jet, and a '77 350 HEI. Lost all my low-RPM torque, 2 weeks of playing with the spark advance curve never got it all back.
When a converter doesn't flash to its rated stall, that's a lack of torque out of the engine, which is usually a tuning problem. If you're running a near-stock LG4, that's no surprise, but even so, the B&M should feel different than a stocker. So what's your initial timing at? What cam is in it? What heads are on it? 190-cc heads on a 350 will cost huge torque until around 3500 RPM. Even a 406 doesn't need more than 180-cc heads to make over 525 HP on a mild street cam. If your intake closing is later than ~35* at 0.050", that's not helping, either
AmpleUnicorn88
South West Region
28
May 22, 2017 12:47 PM
85@IRocZ
May 22, 2016 07:41 AM
dpmalibu
Apr 26, 2016 06:32 AM
section 8
Apr 14, 2016 03:45 PM
1992 Trans Am
Interior Parts Wanted
Apr 7, 2016 03:49 PM
