TH350 trans fitting leak. Help.
Old Apr 28, 2016 | 10:04 PM
adamcgodby's Avatar
Car: 1992 z28 Heritage Edition
Engine: 357ci SBC
Transmission: TH-350
Axle/Gears: Stock axles with 3.73 gears
I just installed a th350 into my 92 Camaro. Every time I search for this leak I always find people with a leak at their radiator. Well, this is not what my problem is. Both fittings that my trans cooler lines adapt into (into the case of transmission). Are leaking. Not the small fittings but the ones that actually go into the case of transmission. I am stumped. I have removed and cleaned everything probably 7-8 times and nothing same results, sometimes worse. All the threads look correct. No stripped threads or anything. What could this be?
Old Apr 28, 2016 | 11:01 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: TH350 trans fitting leak. Help.
Some sources say that the cooler adapter fittings are 1/4" NPT (tapered) thread). Others (Jeg's catalog) say its 1/4" NPSM (straight thread).
You might have a mis-match going on between the case threads and the fittings. I tend to believe the threads in the case are NPSM threads. I believe that the straight thread fittings require some kind of seal or sealer.
Bluestreek
Apr 19, 2017 03:16 PM
wiskerchen019
Apr 16, 2016 05:38 PM
mthibode
Apr 12, 2016 07:04 AM
UltRoadWarrior9
Mar 31, 2016 08:16 AM
igotta355z28
Mar 30, 2016 04:50 AM
