Does the pinion angle change with rim diameter?
Old May 26, 2016 | 09:13 AM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
So I found some c5 zo6 rims/tires for my 85 iroc, now I have a vibration at 60-70 mph. I have lca with relocation brackets, Adjustable panhard bar, adjustable torque arm with relocation trans mount, and one inch lowing Springs. Also 2inch spacers front and back for the rim/tires combo. With the 16inch iroc rims it drove very smooth. All I changed was the 2inch spacers and rims, and it's horrible. Should the angle be adjusted up or down word? Zo6 rims are 18rear 17fronts. Thanks for any help.
Old May 26, 2016 | 09:18 AM
RC1's Avatar
RC1
Car: 86 CAMARO SC
Re: Does the pinion angle change with rim diameter?
The pinion angle will not change with a wheel/tire change. You've got 3 different items that could be causing this new vibration, so it's probably a good idea to have the wheels re-balanced and go from there.
Old May 26, 2016 | 09:30 AM
big gear head's Avatar
Probably the spacers, or a bent wheel. Your pinion angle did not change, so don't mess with it.
Old May 26, 2016 | 08:10 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
I had them balanced before they got put on, I could try again. I did notice that when I got then back from the balancing shop the drivers side tires were not inflated all the way, so I added air to 38psi all around. Would an inflated tire balance different than a flatted Tire?
Old May 27, 2016 | 07:19 PM
Jack up the rear of the car enough to get the tires off of the ground. Have someone start it and put it in gear. Have them let the tires turn while you watch and see if there is any up and down movement or any wobble. Raise the front tires and turn them by hand and check them too.
Old May 27, 2016 | 09:00 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
I'll try that. You would think the guy at tires plus would notice that. Here's what I'm working with., would really love to get this driving smoothly again.
usetaboost
Mar 7, 2017 09:23 PM
88IROCvertZ
Jun 20, 2016 11:27 AM
Bjerime01
Mar 5, 2016 06:13 PM
Ingram78
Fabrication
17
Jul 29, 2015 06:54 PM
