Will 3:23 to 3:73 make a big difference with a T5?
Old Jun 22, 2016 | 08:16 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Did the T5 swap last year. I have a 3:23 **** end. While it's much more fun to drive, I think the 700R4 actually felt faster. Wanted to know how much of a difference a ratio change might make. Considering a 3:73
Old Jun 22, 2016 | 09:25 PM
Re: Will 3:23 to 3:73 make a big difference with a T5?
It's pretty massive.
Too much for a TPI motor, even where you are, where the speed limits are absurdly low. Last time I was in Mississauga (and Vaughn and Etobicoke and various other nearby places...) acoupla months ago, I did have to drive about 90 km/hr once or twice, on the 410 and the 401. TPI limits useful engine RPM so bad, that you might find it slows the car down, because it'll reach the peter-out point too quick.
IMO 3.23 is probably the best all-around TPI gear, with the possible exception of 3.42. But IMO there's not enough difference between 3.23 and 3.42 to make that change, although if you had 2.73 or something, it would be a different matter.
Old Jun 23, 2016 | 08:55 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i went from 3.23 to 3.73's with an lg4 carb t5 and noticed a big difference. now i'm sporting TPI and a tremec tko 600 with 3.73s and it's a beast of a street car
Old Jun 23, 2016 | 09:17 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Basically you will be doing about 10mph less in each gear. So decide if that is what you want.
Old Jun 23, 2016 | 11:19 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Good point. I do want to get around to changing the intake and runners to a better flowing system as well as the heads. Perhaps I should do that first. Not looking for a strip car by any means. Just want something a bit more punchy.
Old Jun 23, 2016 | 08:12 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The V8 T5 ratios (I prefer the 0.63 fifth) and 3.73 rear is a very tractable combination.
Don't just change the intake and runners. Go for a whole intake swap. TPI sucks with 3.73s. In other words, a Q-jet is loads more fun on the same engine, assuming 3.73s.
ISUcyclones3
Jan 5, 2018 05:30 PM
articwhiteZ
Alternative Port EFI Intakes
Jul 8, 2016 05:09 AM
T_P_S
Jun 25, 2016 04:56 PM
Reborn756
Jun 22, 2016 07:54 PM
maroe624
Jun 6, 2016 12:30 PM
