Engine swap and 700r4 won't shift
Old Jun 26, 2016 | 06:21 PM
toronto formula's Avatar
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
Hi
I had a 305 and no tranny problems
One month ago I swapped in a 383. The tranny is a 700r4 and shifts fine in when I leave in drive or overdrive.
When I manually shift 1-2 is ok, 2-d engine revs to 6k and I back off.
Same problem d to overdrive with manual shifting
Some questions
What triggers shifting when car shifts in auto?
What triggers shifting when you manually shift?
Is this a tv cable issue or something else?
Any help is appreciated
Old Jun 26, 2016 | 07:14 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Engine swap and 700r4 won't shift
TV cable, do not drive this anymore until you properly set it
Old Jun 26, 2016 | 08:34 PM
Thanks for reply
Is it ok to drive in auto with no manual shifting
Is the problem basically blowing my engine due to high engine rpm- probably stupid question but I want a clear understanding
Old Jun 26, 2016 | 09:37 PM
TylerSteez's Avatar
Engine: 383 stroker
Originally Posted by toronto formula
Thanks for reply
Nope, do not drive it at all or you will blow the transmission, not the engine.
I'm not the most knowledgable in the inner workings of an auto transmission but pretty much the tv cable controls the line pressure inside the trans, when it's incorrectly set it will destroy a 700r4 very fast.
Luckily setting them is very easy to do and there are tons of videos and write ups about it.
Go under the hood and find the tv cable end that mounts to the bracket by the intake, press in on the D shaped button and slide the slider all the way in torwards the firewall. Then get in the car and press the gas pedal all the way to the floor, make sure you go all the way. As you push it to the floor you should hear the cables ratchet thing click as it slides out to the correct position.
Also double check you have the correct amount of automatic transmission fluid in the trans. Did you have the car running as you filled the trans fluid? I'm not doubting your mechanical skills when I say this, I just don't want you to blow the trans over something that's easily overlooked
Old Jun 27, 2016 | 05:49 PM
Thanks for the info and help. I am going to adjust tv cable
GhostRider_fr
Aug 6, 2019 11:23 AM
epsmotorsports
Jul 15, 2016 03:27 PM
soulbounder
Jun 24, 2016 05:55 PM
Buttpole
Jun 24, 2016 11:44 AM
Reborn756
Jun 22, 2016 07:54 PM
