Press on Governer Cap Issues
Old Jul 15, 2016 | 03:37 PM
80smtn's Avatar
Car: 1986 Custom Convertible Trans Am
Engine: 305 Carb
86 Custom Convertible Trans Am 305
Ok I just changed out the weights to some lighter ones and shifting right where I want them. Used weights 2 and 3 and stock springs and shifts about 5300 RPM. Up from 3400.
The question: The kit came with an o ring to put on the governer cap. When i took the old one off there was no o ring.
1. Does the 700r4 press on cap require an o ring?
2. Cant get the top of the cover to press on. Not enough room to work with. Any suggestions? Will removing the tranny cross member and taking the dizzy cap off allow me to lower the tranny a few inches so i have room to work. Don't really want to do that but I'm open to anything at this point.
Old Jul 16, 2016 | 01:50 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Press on Governer Cap Issues
How did you replace the weights on the governor, road test it and then have the need to ask question No. 2?
Use the o-ring.
Old Jul 17, 2016 | 10:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If there wasn't an o-ring originally, then don't use it. Some came with them while others didn't. I used a thin layer of non-hardening Permatex on the sealing lip.
Getting the cap back on is difficult with the trans in the car. Whatever you do, do not hammer on the center of the cap Only apply pressure to the lip around the edge.
IIRC, it has been a while, I used a long metal rod or such to get to the upper area of the cap. Removing the crossmember and lowering the trans will provide additional room.
RBob.
Old Jul 18, 2016 | 08:23 AM
80smtn's Avatar
Engine: 305 Carb
Thanks,
I RTV'd the cap with O ring last night. It seems to not have leaked during the test drive. Couldn't get the cap on all the way but hopefully it sealed. I will know more when i get a chance to really put it through its paces. Wasn't quite sure if i should use RTV silicone or a permatex aircraft sealer. Prob. should have gone with the Permatex sealer. If doesn't work I'll try dropping the tranny. Thanks guys, J
IROC AND ROLL
Mar 29, 2016 09:52 AM
Onion
Mar 19, 2016 03:08 PM
1988_f-bird
Mar 15, 2016 01:06 AM
Todd85
Aftermarket Product Review
Oct 31, 2000 02:50 AM
