sealing T56 question
Old Aug 5, 2016 | 09:33 AM
johnw999's Avatar
I removed the front plate of my T56 so that I could measure run-out with a quicktime bellhousing. The I removed the tail housing for the mechanical speedometer conversion. It's time to put the transmission back together. I bought the sealant. It looks like a thin film of the old sealant is still along the edge. How do I get that off? I'm assuming the front plate and transmission case have to be clean before I try to reseal. Thanks
Old Aug 5, 2016 | 09:41 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: sealing T56 question
Razor blade or scraper. Wire brush.
Go thin on the bead you apply to the case before reassembly.
And while you're in there, now would be an optimal time to verify bearing endplay/preload. Assuming it was used.
Old Aug 6, 2016 | 01:56 PM
I'd avoid mechanical means as much as possible, and just soak the sealant with lacquer thinner for a bit. It'll come RIGHT off.
86CamaroDan
Apr 29, 2016 11:25 AM
wiskerchen019
Apr 16, 2016 05:38 PM
jsr1485
Exterior Parts Wanted
Apr 14, 2016 04:12 PM
camaroyoungster
Mar 17, 2016 03:33 PM
