tko600 and Fortes VSS Adpater Question
Old Sep 2, 2016 | 03:49 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
For those who have done a TKO600 swap. I picked up the VSS adapter from Fortes...for the life of me I can sort out how the long black adapter that the stock VSS goes into the trans. I removed the one which was on the trans and thought the adapater would slide right in...no so. Just does not seem like it wants to go/is too long.
Any suggestions/help from others would be appreciated - all else seemed fairly smooth with the swap.
DK
Old Sep 3, 2016 | 09:37 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: tko600 and Fortes VSS Adpater Question
The tko has 2 Speedo ports. Are you in the correct port
Iirc one port is for a mechanical sender, and is forward more. The rear most port is for the electric sender. Also the adapter they sell is for the mechanical.and doesn't work.at.all. Still have one somewhere
wiskerchen019
Apr 16, 2016 05:38 PM
J-money
Apr 10, 2016 08:43 AM
89 formula TPI
Mar 28, 2016 08:01 AM
Polo Z03
Mar 27, 2016 08:17 PM
