700r4 4-3 downshift
Old Feb 18, 2017 | 10:14 AM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
700r4 4-3 downshift
allright allright I know its all been said before so installed the sonnax tv plunger and sleeve kit 77966-94mk. supposed to eliminate the 4-3 downshift at wide open throttle. problem is it still down shifts. any thoughts on this? could the tv cable still be adjusted wrong?
Old Feb 18, 2017 | 11:31 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 700r4 4-3 downshift
I can't speak for the Sonnax but some of the a/m valves still allow the downshift.
Try: https://www.thirdgen.org/forums/tran...wot-3-4-a.html
Old Feb 18, 2017 | 12:10 PM
ziggy89's Avatar
Engine: 383
yeah ive seen the modification was hoping to avoid it. the new sleeve was supposed to cure it.
Old Feb 18, 2017 | 06:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
From their website:
http://www.sonnax.com/parts/2513-thr...nger-valve-kit
"Prevents forced 4-3 kickdown below three-quarter throttle"
The B-Body fix kit (discontinued) or the stock sleeve modified is the way to go.
RBob.
Old Feb 24, 2017 | 07:59 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
With the modified sleeve, I could do a 4-3 shift at anything below 85 mph. Once you get past that, it would stay in O/D. So yes, you can still make a 4-3 shift when you're on the highway and want to pass somebody.
Old Mar 1, 2017 | 12:31 AM
Pro Built Automatics's Avatar
Yes, that is correct. Depending on the rear end gear ratio, will mostly determine when the 4-3 downshift goes away. 80 - 85 mph seems to be the numbers I have seen when it stops downshifting using the modified TV plunger sleeve.
Old Mar 1, 2017 | 08:36 PM
ziggy89's Avatar
Engine: 383
that's good to know. wonder how it would be with 4.11 vs your 3.27 gears. and is it going to try and make a wot 3/4 upshift above 80-85?
Old Mar 3, 2017 | 05:11 PM
With the lower the gears 3.73's, 4.11's, 4.56's the lower the speed to get 3-4 WOT shifts and eliminate 4-3 downshifts when blocking the 4-3 passages in the TV plunger sleeve or the aftermarket sleeve.
