Removing throwout bearing from a T-5
Old Mar 1, 2017 | 02:37 PM
Jordan Dorn's Avatar
Car: 1990 Camaro RS 5-speed
Engine: 305 TBI
Hi all, I need to replace my throwout bearing in my T-5, with proper tools and a garage, how hard is it to get to?
Thanks in advance,
Jordan
Old Mar 1, 2017 | 02:58 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Removing throwout bearing from a T-5
Take out the transmission and it is just sitting on the fork in the bellhousing. Not hard at all in a T5 car.
Old Mar 1, 2017 | 03:18 PM
gt4373's Avatar
Transmission: 5-Speed Manual
https://www.2carpros.com/articles/th...ng-replacement
Old Mar 1, 2017 | 03:20 PM
midias's Avatar
That is not the same this as our T5 here are some pics of ours
https://www.thirdgen.org/forums/tran...y-t5-swap.html
Old Mar 1, 2017 | 04:49 PM
Engine: 305 TBI
thanks for your input! i've never done anything like this before and just wanted to make sure i didn't have to disassemble to the point where I wouldn't be able to put it back together
Old Mar 1, 2017 | 07:54 PM
midias's Avatar
It is a fairly easy job, drain trans, pull shiftier, drive shaft, transmission, replace throwout bearing (make sure you install it the same way it came out. Then reverse.
Fillt he trans though the shifter hole
Old Mar 1, 2017 | 08:26 PM
Before going through all that...
Why do you think you need to replace the throwout bearing?
Instead of concentrating on how to kill the alligators, or even how to drain the swamp, let's find out about how what you're REALLY doing is building a bridge OVER the swamp.
Old Mar 2, 2017 | 09:44 AM
Engine: 305 TBI
theres a squealing noise that disappears whenever I push the clutch in, this transmission isn't staying in the car forever, once I get interior and bodywork/ paint done the next step is to make more power, but that won't be for another year
