700R4 won't move in Overdrive, Drives Normally in Drive.
Old Mar 6, 2017 | 04:01 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
Earlier today while I was driving my car was running normally. I was driving down a back road waiting to turn on to a highway, My car had been in overdrive. After I made the turn my car wouldn't accelerate and was acting like it was in Neutral. The engine revs but the car won't physically move!
When I put it in Drive it drives normally but of course no 4th gear. However both Neutral and Overdrive act like I am in neutral.
Any idea of what it could be?
I'm guessing it's time for a rebuild.
Edit:
Problem Solved, the input sprag inside the tranny broke.
Old Mar 6, 2017 | 08:49 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 700R4 won't move in Overdrive, Drives Normally in Drive.
Your description of when the problem occurs isn't clear. It seems like your car moved off from a stop in OD and then acted like it was in neutral?
With the trans in OD, does it move forward from a standing stop?
Or does it act like it's in neutral after it shifts into 2nd or 3rd gear?
Old Mar 6, 2017 | 08:53 PM
Engine: LB9 305 TPI
Basically what you said in the first sentence. It was running fine in OD, after I braked for a stopped and tried to move again it wouldn't move. IN OD it acts like it's in neutral. The engine revs and the car won't move. It acts like it's in neutral as soon as I put it in OD.
Old Mar 7, 2017 | 09:37 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
I would check the shifter cable. Take it off and make sure when the car is in park the end of the cable lines up with the linkage. Then do the same thing in drive. Good luck!
Old Mar 8, 2017 | 05:16 PM
Engine: LB9 305 TPI
Do you think Headers could be blocking the cable or linkage? I did some Googling and found that this has happened on several different types of cars. Ever since I got my exhaust done it sounds like the transmission was hitting the exhaust (exterior noise) when it was put in OD or when it shifted from 1 to 2.
However, I had the headers done in October and it's now March do you think it would take that long to notice?
I'm taking it to the transmission shop tomorrow, hopefully I can find more answers.
Old Mar 19, 2017 | 05:30 PM
Engine: LB9 305 TPI
I forgot to update this thread. In case anyone was wondering, it was the input sprag broke.
Old Mar 20, 2017 | 10:51 PM
Pro Built Automatics's Avatar
A broken input sprag will do this.
Old May 9, 2017 | 12:19 AM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
My 700 is doing the same thing, put it in OD and acts like neutral, shift down 1 gear and goes. Ugh, at least I have an idea
