t56 swap question
Old Apr 3, 2017 | 07:21 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
t56 swap question
i have a 88 gta 305 tpi t5
I am getting my hands on a full 95 lt1 t56 swap....
now do I use lt1 starter
and can I re use my t5 torque arm or do I use the lt1
im super excited
let me now
Old Apr 3, 2017 | 08:24 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t56 swap question
Do the 2.66 1st gear only after you have some gear and some cubic inches.
Either starter works with the LT1 T56 bellhousing.
An 88 torque arm probably has the same "W" or "M" shape to the front of it as the 95 and can be re-used.
Old Apr 3, 2017 | 11:53 PM
"John"'s Avatar
Car: 91 Camaro RS
Engine: 350 crate engine 360ish HP
Transmission: T5 5 speed manual
Axle/Gears: 3.42 10 bolt POSI
If you are using an lt1 flywheel (which I'd imagine you would) you will need to use a lt1 starter. Something to do with the tooth count i think
Old Apr 4, 2017 | 11:15 AM
bensbaby's Avatar
Engine: 383 built
so same starter and same torque arm
ty good to know
Old Apr 4, 2017 | 12:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Tooth count is the same on LT1 vs standard SBC flywheel. 153 tooth
Old Apr 4, 2017 | 12:05 PM
"John"'s Avatar
Car: 91 Camaro RS
I know i couldnt use a lt1 starter on my sbc. I wanna say lt1 is 168 tooth but you could be correct.
Old Apr 4, 2017 | 12:20 PM
"John"'s Avatar
Car: 91 Camaro RS
I stand corrected. LT1 flywheel is 153.
http://www.ls1lt1.com/forum/lt1-%7C-...arter-lt1.html
It should work. I don't know why I didn't just use mine instead of buying a starter.
https://www.thirdgen.org/forums/tech...atability.html
Old Apr 4, 2017 | 02:37 PM
bensbaby's Avatar
Engine: 383 built
so just to confirm
I can use my 88 sbc starter and my 88 sbc t5 torque arm
Old Apr 4, 2017 | 03:38 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Yeah but personally I would go ahead and replace the starter while you're down there, unless it has been replaced in the last few years. Aftermarket varieties start at $80 and are much more friendly to install and work with. I thought the LT4 starter was a mini or higher torque starter.
Old Apr 4, 2017 | 07:29 PM
bensbaby's Avatar
Engine: 383 built
my starters new a few years ago
so I can re use it
and what torque arm do I use
mine or the lt1
Old Apr 4, 2017 | 09:11 PM
jmd's Avatar
jmd
if you have a true 305 starter, it will work.
350 starter will not.
Torque arm should be the same.
