84 z28 transmission doesn't match 350
Car: 1984 z28
Transmission: t5
I recently bought an 84 z28 which has a 350 with some modifications -not sure what all is done to it, the paperwork for the engine is at the shop right now-, and being quite new to this and not very mechanically inclined, thought it was a solid car, until I got it about 40 miles down the road and the transmission blew up. The housing broke and I had to get it hauled to the shop. It's been in the shop for almost a month and a half now. They found a bellhousing that matches the tranny but they said in order to make it fit, it would have to be cut. So i am assuming that the transmission will probably have to be replaced with one that can bolt up to the 350. Now, at this point I don't know what kind of transmission is in it, nor specifics on what kind of 350 it is. My question is, should I just have them yank out that transmission and just find another transmission that will bolt up. Feel free to ask questions as I am sure I left out some pertinent information.
Engine: 4++,350 & 305 CIs
Re: 84 z28 transmission doesn't match 350
We really need more information. You didn't say but I'm guessing its a 5speed car?
If so, you just need a bellhousing for a 85-92 F-body.
All sbc uses the same bellhousing pattern.
We really need more information - with pictures. Either the car is highly modified and takes a non standard transmission or the shop you took it too doesn't know F bodies and so are lost.
This is the kind of car you should consider working on yourself. If you aren't willing to do that then probably something newer will be easier to find reasonable prices and knowledge at random shops local to you. The 3rd gen F body isnt that complicated but its getting old so you need to find someone that knows what they are looking at or can do a simple google search and figure it out.
GD
GD
Car: 1984 z28
Transmission: t5
Just went into the shop to take a look. We can't figure out what kind of engine it is to match a transmission. The original build had cut the bellhousing to fit. They think it's the original transmission with a 350 put in. The people I bought it from doesn't know where the engine came from either.
Car: 1984 z28
Transmission: t5
So without knowing what type of engine it is. What options are there besides Jerry rigging the bellhousing again. And is there a way to identify the engine? They said they pulled the numbers off the engine and that didn't help either.
Well, your first course of action is to determine what engine you have. If your mechanic can't figure that out, you may want to consider a new mechanic.
They should be able to pull the casting numbers off the block to identify it.
Car: 1984 z28
Transmission: t5
Yea he said he did that and he said that didn't help? Not sure how that didn't help. I am quite new to this so I am sort of at the mercy of the shop. They are very reputable and I trust them with my main vehicle.
Car: 1984 z28
Transmission: t5
I am not sure as of right now. I'm speaking with the owner tomorrow about all of this and decide with him which direction we want to go. I'll ask him about the clutch as well.
Car: 1984 z28
Transmission: t5
What reason would there be that finding the casting number not help in identifying the engine?
Car: 1988 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 2.77 Posi
See if YOU can get the casting #'s and either post them here for others to decode, or google them. Plenty of info on the web regarding GM engine casting #'s.
It really doesn't matter what the engine is internally if it's a sbc. If the shop can't look at the external architecture and tell whether or not it's a sbc you should definitely find another shop. Why is it that you can't reuse the bellhousing that's in the car currently. You said the tranny blew up, but the bellhousing should be fine unless it blew up literally. Pictures would help a great deal, you can upload them from your phone.
Car: 1984 z28
Transmission: t5
My apologies, when I went in today, he showed me the old bellhousing, it was shattered, and he also showed me how they had cut it to let it fit with the current transmission and engine. He said the transmission seems to be fine.
Pictures would help a ton
Car: 1984 z28
Transmission: t5
The casting number is 3970010 GM 85 and it had a t5 tranny
There's several possibilities with that block.
69' 302 Z/28 4 bolt main
327 truck and industrial
350 from 1969 - 1980
The block can be either 2 or 4 bolt main.
You have to look at suffix letter in front of the block on the pass. side.There two or three letters. That will tell you the history of the motor. If it was manufactured in 1970 or later, it's most likely a 350.
Car: 82 Z28
Transmission: TH350 for now
Is it possible this is a V6 bell housing T5 trying to mate to a SBC?? Not sure how the hell they cut it to fit though!
Car: 1984 z28
Transmission: t5
He showed me that the housing doesn't fit over the flywheel. So they made a idk like 3 inch 90 degree cut and continued the cut around probably halfway so it would fit. Sure was a hatch job. He thinks he found the correct bellhousing today though. So we will see there.
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Sounds like it may be a large SBC flywheel? There are 2 flywheel sizes & the T5 bell housing only works with the smaller one if I recall correctly. If this is indeed your issue you'll need.
1)correct size flywheel for 2 piece RMS SBC
2)correct starter for that size flywheel
3)correct clutch for that size flywheel
4)bellhousing for T5/SBC with the correct clutch previsions for your car (hydraulic or Z-bar)
Again, if the shop can't figure that out find a different shop to work on this car. Just because they know about your daily driver, which I would assume is a more modern vehicle, doesn't mean they know the classics.
1 Post
Just found this tidbit of info on the internet
"That's because the 168T flywheel is 11" diameter compared to the 153T at 10.4""
Have the shop measure the outer diameter of the flywheel, if it's 11" you have the wrong flywheel.
Car: check
Engine: check
Transmission: check
RBob.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
agreed. guaranteed that the motor has the staggered bolt pattern for the starter and instead of adding the second bolt hole to fit the starter for the 158 tooth flywheel the PO hacked the bell housing.
Car: 1984 z28
Transmission: t5
Got the bellhousing on, it fits great, its extra thick so should be much stronger. Cars running great
