lockup issue
Old Jun 4, 2017 | 03:24 PM
dagab's Avatar
Car: Camaro iroc z conv
Engine: 350 tpi
Transmission: th700r4
Axle/Gears: gen 4 rear axel 3.27 ratio
lockup issue
my car wont lock up, is there a fuse for this or which circuit does it draw power from the fuse box?
Secondly my third brake light doesnt work, can these things be related? ive searched the interwebs but i cant get a clear answer. It cuts the cruise control when i apply the brake pedal if that helps.
and no i havent checked the brake switch, but can that be the problem?
Its a 90 350tpi camaro with a th700r4 trans, the problem began when i swapped the old 305 tpi engine out for the bigger 350, also its a convertible fyi
Old Jun 7, 2017 | 07:04 AM
1982Z28Modified's Avatar
Car: 1982 Z28
Engine: 5.0L
Axle/Gears: Ten Bolt Disc Posi 3.23
Re: lockup issue
It sounds like when you swapped engines you disconnected or damaged the wiring harness to the transmission. You center brake light is probably a bad bulb. And the cruise control should cut out when you apply the brake.
No fuse for lockup, it comes direct from computer. Brake switch could be defective if all brake lights wont come on.
Old Jun 7, 2017 | 01:50 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: lockup issue
TCC Lockup solenoid could be bad. Piece o Cake to change out:
Drain and drop pan
Remove Filter
UnPlug and remove old TCC Solenoid
Install new TCC Solenoid
Install new Filter
Install Pan
Refill and check test drive
EDIT: Install a new 4th gear Pressure Switch while you're in there
Old Jun 8, 2017 | 10:34 AM
dagab's Avatar
Engine: 350 tpi
Re: lockup issue
Ok stunds like good ideas
Il check it out later in The month, should i test the solenoid or just replace it?
Old Jun 8, 2017 | 10:43 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: lockup issue
Since you went to all the trouble dropping pan and all, I would just change it along with the pressure switch.
Old Jun 8, 2017 | 10:50 AM
dagab's Avatar
Engine: 350 tpi
Re: lockup issue
Yeah sounds like a plan, hopefully i can find the parts in sweden, butik that shouldnt be a problem ��
Old Jun 8, 2017 | 11:10 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: lockup issue
Old Aug 17, 2017 | 12:47 PM
dagab's Avatar
Engine: 350 tpi
Re: lockup issue
I havent changed the solenoid yet but it will engage the lockup in 2 and 3 but not in 4th, I did that by connecting a and f in the aldl connector to a switch, does anyone have any idea of what kind of problem i might have with my trans?
