Can't Shift into Park or Reverse.
Old Jan 17, 2018 | 12:47 PM
SubjectSigma's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 350ci TPI
So I've been searching for an answer for a couple months with no success.
My Trans will not go into Reverse or Park. It stops at Neutral. No the cable isn't messed up as I still can't get it into Park or Reverse with the selector arm on the trans. I've pretty much condemned the trans unless someone knows what's up. Also it drives fine in all of the forward gears.
Old Jan 17, 2018 | 08:27 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Can't Shift into Park or Reverse.
You might get lucky,.... If it's NOT the cable or Park-Lock cable than the linkage inside the tranny might have busted. I had something similar happen to me before. Once I dropped the tranny pan I found that the linkage/arm (where the cable attaches ) was screwed up and I needed to replace it before the tranny should shift properly again.
First - re-check the cable to BE SURE ! disconnect it at the tranny and then work it though it's full range - just to BE SURE ! If the cable really is OK;
get yourself a tranny filter and some fluid,... drop the pan and inspect the linkages to see if that stuff looks OK. Fingers crossed for you dude !!! I've got some spare 700R4 internals stashed in the garage 'just in case' so feel free to send me a PM if you need any of those small parts. ( Pics help ! )
musclecar70sfan
Jul 2, 2011 05:46 PM
Jesse076
Jun 18, 2010 11:43 AM
Kevman
Mar 13, 2009 07:19 PM
Z28cross-fire
Sep 1, 2004 08:48 PM
redbird_400
Jun 29, 2003 06:45 PM
